I need a serail number from a plustek scanner to install a software that I use to edit photos and...
(More)
I need a serail number from a plustek scanner to install a software that I use to edit photos and the instalation disc ask me for the seail number and I already got rid of it
I have uninstalled my scanner and when I came to re-install it I found the CD was for Windows 3.1...
(More)
I have uninstalled my scanner and when I came to re-install it I found the CD was for Windows 3.1 and 95 only and my XP will not recognise the format. Where can I get XP software for my Plustek Optic Pro 12000P ? Thanks
OpticPro 12000P scanner on XP worked fine for past number of years suddenly results in b/w printouts...
(More)
OpticPro 12000P scanner on XP worked fine for past number of years suddenly results in b/w printouts for color documents. Epson stylus 860 printer prints color documents directly from computer with no problem.
Tengo un problema: cuando le doy a escanear, a?n seleccionando todo el ?rea de escaneado, no llega...
(More)
Tengo un problema: cuando le doy a escanear, a?n seleccionando todo el ?rea de escaneado, no llega al final del cristal. Y he probado con Windows 98 SE y funciona perfectamente. En la ventana de predigitalizaci?n llega hasta el 26, y escaneando llega al 28, que no es un A4. Creo que es un problema de Drivers, ya que Plustek no hace el driver de este scanner para xp. Alguien me puede ayudar? Gracias
