Question about Maytag MER5775Q Electric Kitchen Range
Maytag smoothtop kitchen range
Hi - my daughter moved into a new house and has a Maytag range (smoothtop). The left front burner - small one - was working when they inspected the house but it is not working now. Are there any tricks to find out what is wrong? Can you suggest best way to fix it?
  • 290 Answers
The only way to find out for sure is to check the voltage to the element.
Most of the ranges have 2 or 3 screws under the front of the top. Remove them and the top will tilt up. Be careful, there is voltage on some of the wires.
Turn the switch on and check for voltage across the element terminals. If you have 240V, then the switch is ok and you probably need an element.
If you can post the complete model number from the tag on the back of the console, I may be able to give a little better directions.
Posted on Nov 30, 2007
  • Michael  Lindley
    Michael Lindley Dec 04, 2007
    Just wanted to follow up on your stove problem and see if you were able to find the problem.
Only one burner doesn't work on my maytag gemini stove
MET8776BS Maytag Gemini Smoothtop Double Oven Range
Rating: 4.5 - ‎94 reviews MET8776BS Maytag Gemini Smoothtop Double Oven Range - Stainless Steel - Reviews ... Really like the features, however one burner doesn't work, after a month.... 2 ovens sure beats the storage bin underneath! the only negative I can think of is ...I bought my double oven a few months ago and am very happy with it.
Oct 16, 2015 | Maytag Kitchen Ranges
I have a maytag performs electric stove mt left front burner will not heat up
the burner needs to be changed. you cna order from maytag or an appliance dealer.
Mar 08, 2011 | Maytag PER5710 Performa Electric Kitchen...
My Maytag kitchen range left front burner does not ignite/clic
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
Sep 05, 2010 | Maytag MGS5770 Gas Kitchen Range
I am trying to replace a burner on my amana smoothtop electric range. I have removed the three screws above the overn door (inside). The top is loose but something seems to still be holding it. Any...
most ovens usually have 2-3 screws located along bottom edge of the smoothtop in the front..check the far left and far right corners in the front /if all screws are removed,you may need to pull slightly forward then raise
Mar 06, 2010 | Amana AER5715QAS Electric Kitchen Range
Maytag MGR5750 Gas Kitchen Range. How do I replace ignitor on right front burner?
HI on some the front burner will lift right out and you will see the elctrode wire remove two screws it should come out
Jan 30, 2010 | Maytag MGR5750 Gas Kitchen Range
Need a new element for the large front burner on my Maytag Precision Control 500 smoothtop stove
That is the 2700W element. I have it available for $157.35 plus shipping.
Email me at if you would like to purchase this part
Oct 17, 2009 | Maytag MER5775Q Electric Kitchen Range
One burner will not turn on - This is a Maytag Precision Touch control 500 electric smoothtop
hi there,
on this case try to clean the gas burner for any dust and corrosion inside. also check and test the ignititer of the stove/
let me know.
Jun 02, 2009 | Maytag MER5770 Electric Kitchen Range
JBP78W electric smoothtop small burner in dual burner not working
you call a repairman, Like I did , expect to pay 150.00 or more as the small burner and large one are in the same ceramic holder
Oct 17, 2017 | GE Spectra JBP78 Electric Kitchen Range
1/2 of burner works
The burner is bad and needs replaced. Broken coil in the burner causes this. Check your owners manual because most come with a 5 year warranty on the burners.
Nov 02, 2007 | Maytag MES5870A Electric Kitchen Range
No heat Maytag smoothtop range MERH752BAB
It would have to be under warranty if this happened after only 1 week. I would contact the manufacturer.
Sep 08, 2007 | Kitchen Ranges
Maytag MER5775Q Electric Kitchen Range Logo
203 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
