Question about DVD & Blu-Ray Players
Philips DVP3144 Region Change
After purchasing the above item from Dick Smith Electronics NZ and being assured that it was a "multi zone" I now discover that it needs a code to unlock it. The online help website brought me here.....
Re: Philips DVP3144 Region Change
The fix on the DVP3120 was as follows. I don't know if this works on 3144 - would like to know.
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
Posted on Feb 15, 2008
Solution 3 fixed it! The code for 3144 does not work. There is no preference tab and believe me I have tried all the tabs to try to see if it defaulted. Cheers, Jane
Posted on Oct 15, 2008
Posted on Mar 19, 2008
1. Turn the unit on and open the tray. Take out any disc from the tray.
2. Enter the code 98790 on the remote and press Ok. The 0 on the end is the region. Eg to change it back to a region follow step 1 and enter the code 98794. 4 being the region code in this example.
3. To check the region code follow step 1 and enter the code 966.
Posted on Dec 23, 2007
0 characters
3 Points
Need to get my philips dvd player 3120 onto muliti
Using the remote controller:
Press [SETUP]
Select Preference page
Press [1] [3] [8] [9] [3] [1]
Select region code using [UP] / [DOWN] buttons.
Apr 25, 2009 | Philips DVD & Blu-Ray Players
Problems with Jwin Electronics JD-VD138
I just found this answer from another contributor.
Turn the power on
Close the drawer
Press 9735
Select Region 0
Exit Setup
You now have a multi zone DVD
Jan 31, 2009 | Jwin Electronics JD-VD138 DVD Player
Cannot play other regions discs-only Zone 6
Most DVD are protected by RC (region code) protocol.
You can change your DVD to region-free by some software.
For windows user, DVD decrypter is the best choice.
Powerful function on remove DVD protection and burn dvd.
If you have an access to Macintosh, this smart Mac DVD Copy software would be better.
Nov 22, 2008 | BBK Electronics DVD & Blu-Ray Players
DVD dvp 3120 is currently zone 4. Would like to make it multi zone
1) Go to Setup page
2) Preference page
3) Press 138931
4) Press up/down key to select region code
Sep 13, 2008 | Philips DVP5140 DVD Player
Need multi-region capability
Press "Setup"
Scroll to "Preference" using the Left/Right arrow key
Press "138931" and a popup screen will appear
Use the Up arrow key and select 0 for a region free DVD player
Sep 09, 2008 | Philips DVD & Blu-Ray Players
I wanna knw how to change region on a philips dvd625k to a nz region ?
With the tray open,
key in 9,9,9,9,0
and the player is region free.
The display shows Region: 0
Using 1, 2 etc instead of 0 in the above sequence sets it to region 1, 2 etc
Jul 15, 2008 | DVD & Blu-Ray Players
Region code
need to know how to play multi zone dvd on my panasonic DMR-EH57.
Jul 11, 2008 | Panasonic DMR-EH57 HDD Recorder Player
I am in NZ and have philips 616K dvd player. Have some dvd's origin UK that wont play on my dvd. Comes up wrong region. My daughter also in NZ has played these dvds in NZ but not sure what brand dvd she...
Changing the region code for DVD616K :
1. Press OPEN/CLOSE, and wait for the tray to open.
2. Use the remote control to input digital key '1', '1', '1', 'l' in that
Kindly leave a few seconds between each entry, the microprocessor is slow
with these entries.
3. Press number '7', '8' or '9' to display the current region code of the DVD
4. Press any number of '0' to '6' to set the required region code. The OSD
will display the new region code of the DVD player.
5. Region '0' will be the setting for multi region
6. The region setting will be saved in the FLASH memory.
7. Press OPEN/CLOSE again, the DVD player will return to normal operation.
Jun 28, 2008 | DVD & Blu-Ray Players
Panasonic dmr-eh57 multi-region unlock code
I sent an e-mail to Panasonic New Zealand to ask about this, and they advised:
"Panasonic NZ no longer pre set DVD recorders or players for all region multi-zones.
However, we will multi-zone for all regions on request. This needs to be done by an Authorised Service Centre, as a special service remote is used. Once delivered to one of these agents, the service company will charge the fee to Panasonic NZ."
If you're not in NZ, try contacting Panasonic in your own country. Just call up with your country code after eg. US = .com and NZ = It seems a *lot* easier than all those complicated hacks on the net. Now all I have to do is work out how to disconnect my DVD recorder again, and try to
PS. I realise this question is 11 months old by now, but I hope my response helps someone like me just cruising the internet looking for help.
Feb 11, 2008 | Panasonic DMR-EH57 HDD Recorder Player
DVD & Blu-Ray Players Logo
1,437 people viewed this question
Top DVD & Blu-Ray Players Experts
Are you a DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
