Copiers
Problem for Copiers
Generic problem for all Copiers
Ricoh Aficio 1018 photocopier
By Saralung on Nov 30, 2007
I have a functional problem come up on the display and the code used is "SC320" can you tell me what this code is for, because the book doesn't tell me. The photocopier is Ricoh Aficio 1018
Comments:
Dec 01, 2007
- Thanks Soulvisitor,
I already try to check the connection but the problem still exist.
Do you thing I must replace the polygon motor?
Thanks for your advise
Loves and regards
Sarah Lung
Dec 01, 2007
- Thanks Soulvisitor...
Now the machine can operate again...
Thank you..thanks you..
Regards
Sarah Lung
Dec 02, 2007
- As your advise, I just lube it and its work
Again.. thank you very much, you the best
Thanks & Regards
Sarah Lung
Best Solution
posted on Nov 30, 2007
Very Helpful)
Soulvisitor
Rank: Guru
Rating: 88%, 2355 votes
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Comments:
Nov 30, 2007
- Service manual states -
320 B Polygonal mirror motor error
The polygon mirror motor does not
reach operating speed within 10
seconds after the motor ON signal is
sent, or does not turn on within one of
the 200 ms check intervals during
operation.
fix is
• Polygon mirror motor defective
• Poor connection between the
polygonal mirror motor driver and the
BiCU board
• Damaged cable between BiCU/IOB
and polygonal mirror motor driver
Nov 30, 2007
- poly motor failure is common is copiers, it is a little motor that spins super fast and bonces laser light over page via attached mirror, the motors pack it in, the motor lives inside the laser unit
Dec 01, 2007
- Yes I change about 3 a week in the field on various makes models, you could try a drop of machine oil on motor shaft but that means pulling it apart, refitting only to find more than likely you will need to replace it anyway
Dec 01, 2007
- Good to hear Sara, did you replace motor or just lube it? I'm impressed good on you!
Dec 02, 2007
- Cheers Sarah, if it goes again just replace that motor.
Merry Copying to you
S.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
I have a Lanier MS 105 voice recorder that needs to be repaired. Can you repair older products such... (More)
Answer
my mp220 will not scan, it will only print and photo copy
Answer
Error message 45-1 is being display on Konica Copier model 3135
Answer
konica 1216
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
