Question about Technics SA-EX300 Receiver
Technics sa-ex300 says overload ?
Screen says overload when i touch anything it says switch off power. i was just play music at easy listening level when all of a sudden silence?
thanks for any assitance
  • 1 more comment
  • Anonymous Nov 30, 2007
    My receiver also has the same problem, I believe i have the wrong power cord, but have been unable to find the correct voltage at a used store yet (ie goodwill or a pawn shop) and refuse to shell out 19/20 bucks for a new one... sometimes if i leave it on while it says overload, it will back out and start working, but I haven't been able to keep it consistent. Once i get it working i just leave it on.
  • Wohoo Jun 25, 2008
    Same problem. The reciever is 15 years old and there has´nt been any problems until now. I have unplugged the unit from the wall and waited about 2 or 3 hours before plugging it back in. The reciever starts working again from time to time, but I can´t see that it has anything to do with heat or dust, I have opened it and carefully vacuumed it clean.
  • narutoguy May 05, 2009
    we were play music and it just went off never done this be fore now we have the overload light on
It could be overheating - try aiming a fan at it for a while, see if the problem stops.
Posted on Aug 05, 2008
LOOKING FOR WIRING DIAGRAM FOR SA EX300 TECHNICS HOME RECIVER
SA EX300 Output Transistors are inside these Hybrid IC
Part Number = RSN 3403-P
Aug 01, 2012 | Technics Audio Players & Recorders
Ventilateur de lampli technics sa-ex300 ne marche plus
Vous pouvez acheter de nouvelles lampes num?ro d'article www.rswww.com 655-9693 (T3.8, axial lampe, 10/15V, 55mA)
You can purchase new lamps from www.rswww.com item number 655-9693 (T3.8, axial lamp, 10/15V, 55mA)
Aug 02, 2011 | Technics SA-EX300 Receiver
On switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Mar 08, 2010 | Technics SA-DX750 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
SA8 5.1 receiver overload comes on with no sound
Try checking your fuse if it overloaded then it probably blew it
Oct 22, 2008 | Technics SA-DA8 Receiver
Technics SA-G9057 overload
Check the fan connections at the back. The connections (just two flimsy metal prongs) came apart (I believe), so I have had to re-enforce them with electrical tape so the connections stay together until I investigate a further replacement fan. For now the connections are extremely sensitive to motion/viberation/impact/etc... but it does work now.
Sep 23, 2008 | Technics SA-EX300 Receiver
Technics SA-AX720 AMP
The audio amplifier IC of your device are damaged you need to replace it.
Jul 04, 2008 | Technics SA-AX720 Receiver
Over load on Technics SA-GX130
There is no easy fix for this. Your unit is power itself down to protect itself. There is an obvious short. You will need seek professional assistance.
- OPTiC
Equipment Repair & Service
A DJ Pro Audio Co.
Jan 26, 2008 | Technics SA-AX540 Receiver
Sa-da8 overload and off
Be sure that the EQ settings aren't accidentally putting you over the top as far as demand is concerned. Bass-heavy material? Same conditions apply...accordianman
Jan 21, 2008 | Technics SA-DA8 Receiver
Sa-Da8 Overload and power off
you mite be pushing too much power, try unhooking a few speakers or check the wattage cuz that mite be your problem
Jan 12, 2008 | Technics SA-DA8 Receiver
1,561 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
