Question about Whirlpool 24 in. DU930PWP Built-in Dishwasher
Whirpool diswasher DU929PFGG2 wont draw water
My dishwasher will not draw water the pump will not draw any water all lights are on but nothing happens what are my possible problems and solutions
  • Anonymous Dec 15, 2008
    I fill it with water and it runs fine. How do i fix the fill switch?
  • Anonymous Jan 30, 2009
    My dishwasher will not empty ?
    Scholar:
    New Friend:
  • 67 Answers
The pump may be clogged or the motor start capacitor may be bad or the fill switch may be stuck or the timer may be bad. Fill the dishwasher by hand to just below the door level and close it then see if it will run. If it then runs correctly the problem may be the fill switch. If not, it could be the motor, the cap, or the timer
Posted on Nov 30, 2007
SOURCE:
Bosch diswasher model no.She3ar72uc/22! It gives me a code E-24!!! How can I get rid of that code to get my dishwasher to work?
theres either a problem with the drain pump or the re-circ pump is drawing too much current, if the error appears at the start before it fills with water and there is no water left inside the unit it is the re-circ pump, if its not draining water its a blockage or a faulty drain pump
Jan 10, 2017 | Bosch Dishwashers
Fisher paykel DD609 diswasher - top draw does not drain properly. Water build up in bottom of the top draw even when bottom draw is used.
It is usually due to a small piece of broken glass or plastic blocking the little propellor that pumps the water out, (think of the little paddle in Nemo's tank)
You need to remove the bottom of the machine, undo one screw and twist the pump free, fairly easy, but make sure you turn the power off first. The outlet hose and pump will then be accessible, have a look in and turn the paddle with a screwdriver, bet you will find something blocking it. Shake it out and reassemble
Mar 22, 2008 | Dishwashers
It has not been cleaning good and now it did not drain the water out. What could be the problem. Please help
Something is in the pump blocking the water from getting out. Take the diswasher out if it is installed into a cabinet. Disconnect the drain hose. Turn the dishwasher around and remove the pump and clean it out. If there is nothing inside the pump then the pump is broken and you must replace it. Generally the pump is not working.
Jan 11, 2011 | Kenmore 24 in. 17362 / 17364 / 17369...
GE Nautilus built-in dishwasher suddenly won't spray
micro switch at the door lock has failed. it just happened to me.
I wired it direct and it worked. just dont open the door until you get a new switch. it wont shut off
Jul 11, 2010 | GE Nautilus 24" Built-in Dishwasher
My Frigidaire dishwasher won't start. I just moved into a condo and the dishwasher worked during inspection but now it's not...wondering if it's something I just don't know about. The model number is...
Did you ever get an answer to your problem.
I've got same issue where I turn the diswasher on and nothing happens ... the time just start going down but nothing is happening?
May 22, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Stainless Steel- LitchenAid diswasher will not star
This doe seem that the anti flood system has triggered. This device puts the machiene in pump out mode and shuts off the input water supply.
The device is a safety device that triggers once it detects a water leak (pipe / clamp) and consists of a polystireene float and micro switch at the floor of the washer. First check to see if the float has activated the micro switch and then dry the machiene floor and check for leaks.
Jan 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher won't start
may be in flood mode. tip the unit sideways and see if water leaks from the base if so continue to tip it until it all drains out, then start it on a wash if it starts you have a component leak that will have to be sourced.
Mar 14, 2009 | Dishwashers
Dish washer not working, lights come on but nothing happens, will not drain water that is in there either.
flooding the sink won't have anything to do with the dishwasher.unless the check valve on the dishwasher got stuck closed. Can you hear the pump come on?
Oct 29, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Diswasher
Check the float switch. If it is stuck the machine will start but no water will be allowed in and the pump will turn on to drain the non existant water. This happens often when a small item gets under the float preventing it from allowing the water valve to open. Find the float in the bottom of your machine and make sure it moves freely.
Jan 15, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Whirlpool 24 in. DU930PWP Built-in Dishwasher Logo
292 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
