Question about Emerson EWF2004 20" TV
Video input umlock code for mitsubishi TV VS5020R
Cannot use DVD player. video code is unknown and nobody at mitsubishi seems to have a clue as to what the problem is. I purchased this TV from a neighbor that has moved.
  • Anonymous Dec 18, 2007
    tv picture but no video'
  • Anonymous Jun 21, 2008
    Same problem. We were given the tv, but can't unlock the input code so we can add the dvd player. It seems useless now. Help?
2 Suggested Answers
  • 104 Answers
SOURCE: Can't find the input/video channel for my Emerson TV
universal remotes are tricky, if you have the pamphlet, often times there are several codes for each brand. you have to try all the emerson codes for your universal even tho the power, volume and channel functions may work with several emerson codes, some of these specialized buttons (like input) may only work on your TV with one specific code.
also, if there are any unlabeled buttons on the universal try them with each new emerson code.
Posted on Feb 12, 2009
I need to be able to connect DVD player to output 3 on Mitsubishi Medallion hdtv 1080 we can't seem to get it to work
It needs to be input if you want to display some on the TV from the DVD player. HDMI is the easiest as it's both audio and video.
Jun 01, 2015 | Mitsubishi LT55164 Unisen Medallion 55...
Video Does not work on New Magnavox TV
Hi, it sounds like your problem is that you've selected the wrong "video input" for your DVD player. Your new television most likely has at least 3-4 (sometimes 6-7) different inputs for video. With your DVD player connected and turned on, press the "Source" button on your TV to cycle through the different inputs. Be sure to wait 2-4 seconds between selections to give your TV enough time to switch inputs. If your DVD player has "color coded" output cables, it's most likely a "component" video connection. See if one of your video inputs on the TV is called "Component". Some other video types are Video, DTV, HDMI, SVideo, Component, Composite, RGB, PC Input, etc...
Jul 24, 2013 | Sylvania SDVD7014BJ 7 in. Portable DVD...
How do I hook up a dvd player to vs 4544?
Its a old set but hookup should from a DVD player be to the rear audio and video inputs---note color of jacks on player--you will need for that old set composite--yellow(video and color), red and white for sound.
If the player does not have them (composite) you have a real problem.
Once connected use the input button on the front of the set to change to that input that you hooked the player up to (video 1 or 2 etc.)
May 29, 2012 | Mitsubishi VS-4544 45" TV
When I hook my dvd player up using the Component Video Input I get sound, but no video. Its not the dvd player because i hooked it up to my other tv and it worked fine. Thanks for any assistance
This might be the other TV's Video Input Cable Plug. Could be disconnected somewhere within, it may be disconnected. If your TV has two slots for Audio/Video Input, try using the other Slots maybe. :)
Apr 02, 2010 | Mitsubishi VS-60607 TV
How do I change my remote for TV to Input Video 1?
There should be a button on your remote denoting "Input." If you connect the DVD player to the TV on "video input 1" then push the input button on the remote or TV itself until the DVD appears on your TV (which will be Video 1). Some TVs must have the component (in your case) the "DVD" player connected to the TV before the TV will recognize it. Make sure the DVD is powered up and then push the input button until the DVD player appears on the TV. Depending on your TV inputs, there may be multiple inputs like, Video, Component, DVI, or HDMI. The above are listed in the respective order of "quality." HDMI being the best. Whatever input you hook the DVD player up to on the TV will be the "input" you will look for when pressing the input button. Hope this helps.
Oct 26, 2009 | Mitsubishi WS-48515 48" Rear Projection...
I need to get image
Change the input on your television to the corresponding input of your DVD player's video output.
ie; if your DVD player is hooked up to Video 2, you need to change your tv input to Video 2.
You may have simply not hooked up the video input, as well.
Mar 18, 2009 | Samsung HT-Q100 System
I am trying to connect an akai dvd player to directv, please help
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
Jan 31, 2009 | Akai DVD-3850S DVD Player
Component input makes all pictures black and white?
You can also check to make sure you're on the correct TV input. I've seen this happen if you use S-Video for example, and the TV is set to a composite input by mistake. If you're using S-Video make sure the yellow composite cable is unplugged.
Jan 09, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Emerson EWF2004 20" TV Logo
244 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
