Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washing machine
Hi every time I was clothes I seem to have a problem with lint on all my clothes especially new towels and socks. How can I fix the problem I am having or is it time for a new washer? Thanks
  • gladysdaught Sep 03, 2008
    clothes get lint when i wash them all my clothes. can i clean the lint filter and that help
    Champion:
  • 249 Answers
30 YEARS REPAIRING NEVER HEARD THAT ONE sorry i don't know
Posted on Nov 30, 2007
SOURCE:
Clothes are not drying especially jeans and towels. duct is clear and at end of cycle dryer is hot.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jun 14, 2011 | Kenmore Elite HE4 Electric Dryer
My whirlpool dryer will not dry clothes in one try.takes a second time to dry a load. especially jeans or towels
Make sure the lint filter is free of dirt. If this is a gas dryer, listen for the burner switch on. If you hear it switch on and switches off in less than a minute, you will need a new gas valve solenoid. This part goes part and goes on safety - switch off gas. In return you only get a air dry (not heated).
Mar 01, 2011 | Whirlpool Dryers
My dryer doesn't seem to be drying my clothes. I have to run the cycle 2x for clothes to dry and the lint is cleaned out
Lots of the time lint still gets by and starts to block further down into the ductwork and around the fan.
Unplug dryer from the wall
Pull dryer out and remove hose from the back
Inspect inside with light you can put your arm up to to feel around
Look for the odd sock, clumping of lint or bounce sheets
If dryer is not even warm when running the heat elemnt or thermostat may be faulty
Jan 20, 2011 | Kenmore Dryers
There is a lot of lint especially on black clothes after wash with 6.5kg Front Load Bosch Washing Machine WAE20261AU. How to fix this issue?
Before the wash ad few cups of white vinegar to the washer half filled with water.let it run for sometime and then drain off fully.
Now for the wash add a cup of white vinegar along with the detergent. clothes be pit in inside out, cotton and polyester have different tendencies. so as towels.
So keep them for seperate washing to avoid more build up.
Sep 24, 2010 | Bosch Washing Machines
Ijwant to dry my cloth but when i turn on it appear check filter how i am going to fix
You should empty the lint filter. The lint filter catches all the lint from your clothes and will need cleaned occassionally. I clean my lint filter after every load. Towels usually clog the filter faster than other clothes.
Aug 07, 2010 | LG DLG5932W Gas Dryer
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
Our ge washer is putting a brown looking lint onto the clothes. what could be the cause?
Might be a sock or other small garment that got into the pump. It does happen. Also might be something from a previous load such as a brand new towel that shed lint and stuck to the inner tub.
Has it done this more than just once or twice?
Apr 29, 2010 | GE Washing Machines
My roper REX3514 Dryer will only dry on the time cycle.
If you use a lot of dryer sheets, it will build up an oily residue on the sensor strips causing a "false" reading. Light sandpaper and alchohol over the strips should clean them well. Another possibility, is if you have a mixed load, ie..towels, socks, jeans , if a sock or something light keeps hitting the strips, the dryer thinks the whole load is dry (it doesn't know there are different thing in there) Try keeping loads similar when using auto dry.
Mar 14, 2009 | Roper REX3614KW Electric Dryer
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
Clothes will not wring out water
On this model, first check your pump for proper operation. Wet clothes can be the result of slow spin speed, which can be casued by a binding tub seal or bearing, brake rotor assy. not disengaging properly, or a slipping clutch spring. You also want to check to see if you have anything binding between the tub and basket that will slow it down. Sometimes a sock or lint can wad up and cause a drag.
May 28, 2006 | Maytag MAV6200 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
252 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Paula Hamilton
