On the diplay panel at the very bottom of the left hand side do you see a small little symblos (wrench) touch it the panel will go to a different display, then once there open and close the front door. its reset procedure. Next try, Open the front door youshould see a cover with a small screw, or if the cover is off, you will see two buttons, one is trouble reset the other is initialize the one to (try 1st) the left the trouble reset to the right, two draws down worked with minolta never had both draws go, make sure once the draws open check behind them for paper. Open and close front door first off also
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Testimonial: "Outstanding!!! You solved my problem. "
Thank you sooooo much, This solved my problem.
