Question about Yamaha DVR-S200 DVD Player
Unit wont stay powered up
My dvrs200 shuts down as soon as it turns on the display reads check sp but i have no speakers hooked to it actually nothing hooked up to it can some one help me
  • doggdaa Nov 30, 2007
    thanks ive come to thank that it has something to do with the center speaker when i plug in the speakers to that channel you hear current go to the speaker do you know if i can get just then center channel output board im going to assume that the board just plugs in
    Scholar:
    New Friend:
  • 67 Answers
Check for overheating. Place the unit in a large plastic bag and place it in the refrigerator for 1/2 hour. Don't allow condensation to appear on the unit before powering it up, the heat will evaporate any potential condensation. Put moisture absorber or rice in a paper bag in the plastic bag for safety to absorb any moisture. Then power up. If still inoperative check for DC or AC voltage on speaker connectors. If one side is different, or if DC appears on the outputs, audio output may be shorted. See if plugging in headphones stops the problem, some units disable the audio outputs with headphones plugged in.
Posted on Nov 30, 2007
SP OFF mode?
if you turned it on without speakers hooked to it you may have blown the speaker output amps or if the end of the amp remote wire touched a ground you may have burned a trace on the board did you here it play at the pawn shop? or did it just light up? sometimes the people at the pawn shop think if the unit lights up it is working and sometimes they check them is just hook power to them without speakers if so this can blow the speaker output I would take it back to the pawn shop
Jan 29, 2014 | Kenwood KDC-MP235 CD Player
The radio powers up but turns off after a few seconds
disconnect the speaker wires at the unit and tape them off one by one. Then re-power up the unit, if it still shuts down, it is an internal problem and needs service. If it stays on, re-connect one speaker at a time and test power again. When you find the speaker with the problem it will shut off. It's going into protection and keeping itself from damage. Once you find the bad wire or speaker, check the wire by disconnecting it "at the speaker" and turning the unit back on. if it still cuts out, replace the wire. If it stays on, meter the speaker by checking it for resistance, if your meter reads 1..... the speaker is blown and needs to be replaced. If your not handy with a meter, go to any car audio shop with the speaker and they can test it for you, usually for free. Hope this helps.
Jun 18, 2010 | JVC KD-S6060 CD Player
Aiwa receiver won't turn on
Hello:
This looks like its displaying the Time format. Try disconnecting all speaker one a time and turning on the unit to see if it turns off. Disconnect one speaker at a time and turn the unit on. If it turns off with only one speaker conn then this speaker is your problem. Amps will shut down if a speaker goes bad. Another thing to try is disconnecting all inputs and speakers from the unit and see if it stays on. Then reconnect them one at a time while watching what the unit does during power up. Also you might want to open the device and check for blown fuses. Check for any speaker terminal wires touching each other if so it will shut down thinking there is a short.
Nov 30, 2009 | Aiwa AV-D50 Receiver
HTR-6130 will not turn on
Remove all speakers from the receiver and try powering it up again. If it still shuts down odds are it needs repair of one of the output channels.
Jan 31, 2009 | Yamaha HTR-6130 Receiver
Clarion DXZ385USB
the message you are getting is "amp guard". This is the mesage it will display when a short in a speaker wire or speaker with low impedence is hooked to the internal amp and sends it into protect mode, shutting down the amplifier section while the rest of the unit continues to work.
Check your Factory speaker locations for blown speakers or bare wires to metal.
Dec 28, 2008 | Clarion DXZ475MP CD Player
Yamaha rxv-992 receiver wont power up
Disconnect all your speakers from the receiver. Turn the power on, and see if it stays on. If the unit shuts off with all the speakers disconnected, then you most likely have a faulty unit, and it will need to be repaired or replaced.
If the unit stays on with all the speakers disconnected, then you most likely have a bad speaker or a bad connection with the speaker wire.
Starting with one speaker, hook it up, and turn the unit on, and again see if the unit stays on, or if it shuts off. Do this until the unit shuts off when you connect a speaker.
Then disconnect all the other speakers, and leave the suspect speaker attached. Again, try to power up the unit. If it fails with that speaker attached, but works when it is not attached, then that speaker is your problem.
Sep 02, 2008 | Audio Players & Recorders
HTR-5940 6.1 Channels
Every time this has happened to me it was either due to incorrect speaker impedance or incorrect polarity (+/- wires reversed).
Apr 21, 2008 | Yamaha HTR-5940 Receiver
My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
That is a check the speaker wire error, caused by a short or perceived short. If you look at the back of the receiver you may see 1 strand of the wire loose, they are very hard to see sometimes. You may use banana plugs as it is painful to get everything hooked up without a few loose strands.
If there is still the issue check your speaker connections for the same issue. If they are in ceiling/wall speakers disconnect them all then plug them in one at a time to narrow it down.
If the issue persists perhaps one of your speaker wires has a short somewhere, could be a misplaced drywall screw from hanging a picture, or a carpet tack strip, or a pet deciding it was a nice chew toy.
If you are completely sure it is none of those then I would say it is a bad speaker or receiver. Try changing in and out known good speakers/receivers if you have access to them to see which one it is.
Good luck
Feb 03, 2008 | Yamaha HTR-6030 Receiver
Dual MXD55 W/6/5 SP CD Problems
make sure the speaker grounds are connected to the speaker ground wires on the deck and not the "chassis" ground. also make sure both power wires are hooked up to a power source. the thinner power wire is supposed to be a switched source (like the ignition key or an accessory switch) that turns the unit on and the thicker one is a constant source which actually powers the deck once the switched source is turned on.
Jul 01, 2007 | Dual MXD55 AM/FM/CD/Weather Receiver
Head Unit Shuts Off At a Certain Volume
check your ground, it could be that your antenna is the only source of ground, in which case the deck does not have enough power to stay on when it draws too much power. I've seen exactly what you are saying many many times. Ground it really reallly good.
May 10, 2007 | Alpine CDA-9853 CD Player
Yamaha DVR-S200 DVD Player Logo
90 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
