Question about Pyle Single DIN Motorized 7 TFT Monitor Tv-Tuner - PLTV74R
Audio video im interested in buying PYLE PLTV74R i was woundering if i could hook up my ipod to watch videos and still get sound to my stereo speakers
  • 3 Answers
Don't buy pyle it is chip junk ...i have it and it is pices of crap
Posted on Dec 10, 2007
SOURCE:
Brake bypass
this is on a website link let me try to find it its a wire buddie had same issuue
Jan 27, 2008 | Pyle PLTDN71 Car Video Player
What do you think the problem is as to why my ipod want load up,i keep getting the message ipod communication aborted.
bad receiver in the radio, or, the transmitter on the ipod is bad. try it on another bluetooth source to see if it maintains connection, if not, the ipod could be damaged or bad. If it works with another bluetooth source unit, then the radio has a bluetooth receiver issue.
We sell low priced replacements!
http://advancedelectronic.net/
Nov 22, 2014 | Pyle PLDN74BTI Car Video Player
Ipod tower brookstone problem
The problem is with the speaker connector to your ipod. I have the same unit. Got to ebay and buy Pyle Home PIDOCK1 or similar docking station. This will solve your problem. You can plug this in and have full functionality back of your speaker. Don't bother trying to fix it these have a real problem with the connector and board buy yourself a docking station with remote for about $15 on ebay and it will fix you up. Plug into the input Jack and you are back in business. You can buy a Pyle Home PIDOCK1 Universal iPod/iPhone Docking Station cheap on ebay and it has a remote. It will fit nicely on your speaker and do everything you need it to do.
Jun 12, 2012 | Audio Players & Recorders
Do The Pyle PLG6C need an amp? or can i just connect em straight to my stereo
It depends on your stereo you have installed. Some come with a good amp attached and others do not. I have a factory AC delco and it pushes them just fine. so the answer to that would be based on what stereo you have installed.
Hope that helps.
Mar 13, 2012 | Pyle PLG6C Car Component System
Trying to hook up speakers to Pyle Pro PD1000 stereo receiver w/built-in DVD/CD player. I believe that I have speaker wires hooked up correctly but when I play CD no sound. I can actually hearing sounds...
I went thru user manual..there is no special way of wiring speakers..
pls check carefully the speaker connections again and the "speaker selector" too..
what about "MUTE" button ? it should be "OFF" ...
and try to test it on FM radio first ..
just in case ,if you need the soft USER MANUAL pls visit the URL below..
1000 Watt AM-FM Receiver w/ Built-in DVD/MP3/USB
http://www.pyleaudio.com/sku/PD1000A/1000-Watt-AM-FM-Receiver-w-Built-in-DVDMP3USB
Jul 10, 2011 | Audio Players & Recorders
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
Speaker produces sound even when the zone is off
Since the Pyle speaker is a 4 ohm device, it's likely that when you have other zones on, the change in the impedance will affect the volume. Check to see what impedance your other speakers are (standard is usually 8 ohm), and if your tuner has impedance matching for your zones. If it does not, that's most likely your issue. You could get an impedance matching transformer at Radio Shack to resolve this issue. Please rate my solution, thanks.
Apr 17, 2009 | Pyle PWRC82 Main / Stereo Speaker
I have a Pyle PLD3MU head unit and a sony XM-ZR1252 amp (2 channel) and the car has 2 door speakers, 2 rear deck speakers, and 2 12" subs. What is the best configuration to hook this up?
Run your 12" subs off the amp make sure to Xover for bass only.
Try running the 4 speakers direct to the stereo may not be enough power, Might have to invest in another amp and speaker upgrade to get it sounding just right.
But its a place to start.
Jan 07, 2009 | Pyle PLDVIN7 Car DVD Player
Pyle Single DIN Motorized 7 TFT Monitor Tv-Tuner - PLTV74R Logo
125 people viewed this question
Top Pyle Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
