Question about SanDisk Sansa e250 MP3 Player
Hang, just the light is on, won't respond
Hi, my sansa e250r isn't responding at all. it just stopped in the middle of a song. just the wheel's light is on. i would appreciate a solution.
thanks
ujjawal
  • 1 more comment
  • CofCCougar Nov 30, 2007
    I have the exact same problem...right in the middle of a song it just stopped. The began to fade and is now completely blank (but still lit) and the wheel is lit. Please help...
  • tech_prob Feb 15, 2009
    hey e1 i m facing the same problem!! GOD DAMMIT! wat to do now??
    and e1 the portion that shows the green charging status is stuck there. so i thot mabbe if i connect to the pc for charging using the usb port, but surprisingly the pc said that the device hs malfunctioned and it cannot recognize the port!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!plz get me solved this prob asappp
    i hv the same prob.
YEAH!!!! Hold down the power button for about 30 seconds and it resets....
Posted on Nov 30, 2007
Thankuuuuuuuuuuu it helpd nd the prob is solved!!! cheerssssss
Posted on Feb 15, 2009
E250r+sd only shows about half of songs from both
Having received no response in over a month, I assume this is no longer a problem.
Jun 08, 2010 | SanDisk Sansa e250 MP3 Player
Sansa e250 won't connect
1.try formatting your sansa
2.try to copy again..
3.if it does not work tell me what sansa you are using
May 23, 2009 | SanDisk Sansa e260 MP3 Player
Where is the reset button on the Sansa e250R?
There isn't a dedicated reset button. To reset the unit, press and hold the power button for fifteen seconds.
Feb 28, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250R 2GB got hanged.
where is service center.. in chennai
Sep 23, 2008 | SanDisk Sansa c140 MP3 Player
Sansa Clip 2GB won't transfer songs
I had a similar problem with with one of my mobiles, so not sure if it applies in this case, check the ports, and make sure the device is connected to the correct usb port that the pc has allocated to your portable device (sansa clip)
Sep 17, 2008 | SanDisk Sansa Clip MP3 Player
SANSA e250r ??
my sandisk 250will not change songs it is stuck o #1 icannot move it up or down
May 03, 2008 | SanDisk Sansa e250 MP3 Player
The media device has either stopped responding or has been disconnected
Make sure you're not using the media with another program while you attempt to copy/sync it to your device.
Pretty late response, but meh.
Feb 28, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Device has been disconnected or stopped responding
on your pc turn off any hibernation or sleep modes,also cut the playlist in half.let me know
Jan 06, 2008 | SanDisk Sansa m230 MP3 Player
My Sansa e250R, 2 gigs, froze. Help!
It seems like your E250R is experiencing a temporary system error due to a corrupted song, and needs to be reset. Try to "Soft Reset" your player, press and hold the "Menu" button until the LCD light and scroll wheel light turn off. Since the player was probably left on for more than 7 hours (as you indicated), you would need to re-charge the player before proceeding further. Charge it for at least 2-3 hours. Next, try to format the player to rid of any corruption then re-transfer the songs. If you have subscription songs, then I would suggest to delete the song you last played which caused the error. I hope this helps. There is another solution for the player, but for now this might actually resolve the issue. Let me know the results. :)
Apr 23, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
119 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
