i have a panasonic pt-4743g.when i turn the set on you hear a relay click then the power light flashes 4 times then stops then flashes 5 times.does anyone know what could be the problem. thanks
Comments:
Aug 24, 2009
- i check h/o it was good and resoldered everything and checked all of the resistors around the stk chips and all of them seemed to be good. when put back in set the power light blinks five times.you mentioned replacing the stk chips would that keep the set from turning on. thanks
CK hori out put Transistor, next to or behind that part is a small blue capacitor high voltage 2k volts see if it has burt pin hole if so replace it also resolder convergence plugins and FBT.Your STKs could need replacing they are big black ICs will have part number on them if 110s use 180s Call Mats for parts 1-800-628-`1118
Comments:
Sep 17, 2009
- Yes bad STKs can keep set from coming on one of them controls startup.
i was attemptin to remove the main board from the tv to replace the convergence chips, and pulled on...
(More)
i was attemptin to remove the main board from the tv to replace the convergence chips, and pulled on a red wire that appears to be connected to a "distributor cap looking thing" that then broke. it appears that it was soldered deep incide the part. What is this and is it bad that that i did this, will it work by just re-securing it in the "distributor cap thingy" or did I just ruin the tv to the point its not salavageable, or is this part i broke replaceable and what is it called?
i have a panasonic pt-51hx42 and when you turn it on after about 3 seconds it turns itself back off...
(More)
I HAVE A PANASONIC PT-51HX42 AND WHEN YOU TURN IT ON AFTER ABOUT 3 SECONDS IT TURNS ITSELF BACK OFF AND YOU HAVE TO UNPLUG IT AND PLUG IT BACK IN TO GET IT TO TURN ON AGAIN
I have a panisonic pt4743g when I turned it on it sounded like it was comming on, but then just when...
(More)
I have a panisonic pt4743g when I turned it on it sounded like it was comming on, but then just when black. No sound no picture. The power light flashes three times then stops for about 10 second then flashes again three times the stops fpr 10 seconds. Any Ideas?
wavy lines appear across my panasonic 51hx42f screen when i first turn my tv on. picture is...
(More)
wavy lines appear across my panasonic 51hx42f screen when i first turn my tv on. picture is distorted and makes viewing difficult.
