Question about Epson Stylus CX6600 All-In-One InkJet Printer
Printing blank pages
The CX6600 prints blank pages even in setup mode. Cartidges are new. Please advise.
  • 1 more comment
  • noelhopkins Nov 30, 2007
    I have tried all the options given in the manual but none has worked
  • Anonymous Dec 13, 2007
    I have changed ink cartridges twice, cleaned heads three time, still prints blank pages. Seems to respond fine otherwise, either from scan and PC. Has program changed in cartriges to suit Vista?
  • Anonymous Dec 18, 2007
    I have the same problem and haven't been able to print for a few months now.
    All the Print Cartridges are new but one is a "no name" brand.
    Could that be the problem? This one was actually printing before but now has stopped working all together. The pages are blank but all the ink is full.
    Was I suppose to pull off any other plastic seals on the holes of the ink cartridges?
  • 556 Answers
Check out the online guide and trouble shooting for a solution
The manuals,online guide and trouble shooting sections could help you resolve your problem. Contact support has a chat facility on some pages that may help.
Click this Link
Under Select a Product Range
Choose Multifunction Printersprinting blank pages - 4.gif on the webpage1.gif
Choose Stylus CX6600 on the webpage
Under Select an OS
Choose the operating system1.gif on the machine where you will install the printer on the webpage
Click Confirm Selection
The manuals and documentation link will allow you to download manuals that were on your CD ROM
you may want to bookmark the online guide, if present, to help with future problems -- that probably was not on the CD
Click the back button on the browser
click the Drivers and Software Link
This allows you to download software files that were probably on your installation CD
Click the back button on the browser again
Trouble Shooting and Contact Support could be an interesting link in the future too when and if you have problems.
I hope this helps
Posted on Dec 16, 2007
SOURCE:
Hello my Epson Stylus CX6600 is printing out blank pages, ran nozzle check and Head cleaning, also head allignment, still print blank pages, need help please
if the printers been sitting for some time, the printhead has dried up "not good" printheads generally retail around $100, you can try soaking the bottom of the printhead in metho which may fix some colors but you would be pretty lucky to get all them to work.
Nov 26, 2010 | Epson Stylus CX6600 All-In-One InkJet...
LEXMARK 125 PRINTS BLANK PAGES
have you when into printer properties and done maintence such as "clean cartriges".  If so, it may be possible the ink cartidges are bad.
Mar 01, 2009 | Lexmark X125 All-In-One InkJet Printer
Printer won't print
plzzzzz check whether the ink catridges are compatible to your printer(chk the model number of your ink catridges)
Dec 15, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Hp 1320 prints blank pages
My HP 1320 printer is printing blank pages and it will not even print test pages etc
Nov 03, 2008 | HP LaserJet 1320 Printer
Epson cx6600 printing only magenta even with new cartidges
Try remove and shake the inks and reinstall it back in and test to print. If you have tried more than 4x with the head cleaning it might be your ink pads inside the printer is clogged. Is this still under warranty? You have to call Epson they might help you out with it.
Oct 11, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Open ink cartridge holder
Here are some T/S steps for your problem:
Press the fontx1.gif Color button and open the scanner unit. Follow the messages on the LCD panel to replace the empty cartridge. See :
http://files.support.epson.com/htmldocs/cx66__/cx66__rf/ink_4.htm#replacing%20an%20ink%20cartridge%20a
Running a printer operation check
If you are unable to determine the source of the problem, performing a printer operation check can help you determine whether the problem comes from the CX6600 or the computer.
To perform a printer operation check, follow these steps.
r_1.gif Disconnect the USB cable from your computer. r_2.gif Make sure that Letter-size paper is loaded in the sheet feeder. r_3.gif Press the fontp.gif On button to turn on the CX6600, and make sure the ! Error light is off. r_4.gif Press the Setup Mode button to enter Setup Mode. r_5.gif Press the A or the fontl1.gif/fontr1.gif Select button repeatedly until 3.Nozzle check appears on the LCD panel, then press the fontx1.gif Color button. The CX6600 starts printing. The CX6600 prints an operation check page that includes a nozzle check pattern.
Compare the quality of the printed test page with the sample shown below. If there are no print quality problems, the CX6600 is fine and the problem probably lies with the printer software settings, the application settings, the interface cable (be sure to use a shielded cable), or the computer itself.
If the test page does not print satisfactorily, there is a problem with the CX6600. For example, if bands appear in the check
Please remember to rate Techs who assist you for free :)
Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 05, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Cx6600 printer problem
if you left your printer for two weeks or more without using, the print heads may be stuffiness. In this case (aparently yours cases) you must take your printer to a authorized service, they will can clean (with a proper fluid) or replace the ink heads, if cleaning is not possible.
Mar 16, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Prints blanks
your ink cartidges have dried up and clogged the nozzles. try either new cartidges or try cleaning heads with alcohol dampened cloth.
Aug 30, 2007 | Lexmark Z600 InkJet Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
228 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
