Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Eureka vacuum the suction does not work
  • 1 more comment
  • cyrlisa Dec 04, 2007
    i have no suction from the bottom of the vacuum but the hose does work.
    i have cleaned all the hoses and still no suction from the bottom.
    please send me an email on how i can remove bottom to see if the belt is broken.
    thanks
    email [email protected]
  • nevan Dec 26, 2007
    suction does not work from the bottom, but hose work
  • bwaller14 Mar 01, 2008
    Have the same problem as Pachica, the hose works great, but there is no suction from the main vacuum. This is a brand new vacuum, so I don't believe there is a blockage, although I did check.
The belt that runs along the side has snapped. Take off the cover in front to see.
Posted on Apr 09, 2008
If the hose works great as you say, then you need to take the two screws on the top of the cover out. remove the cover exposing the brush and belt. flip the cover over and remove all the build-up in the channel as this is the suction channel that runs along the brush. if it is clogged then the only place where dirt gets picked up is the area under the hose.
Posted on Apr 03, 2008
The hose between the bottom and the duster thingy is clogged. there is a little ***** to remove the duster from the hose, use a wire hanger or something to be able to get all that stuff out, should work fine. before you begin squeeze that hose part and you should feel stuff in there.
Posted on Mar 11, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
If you have ran over any big objects you might try removing the cover from bottom take out the roller brush and see if it is clogged from the bottom
Posted on Jan 17, 2008
SOURCE:
reddevil6
  • 1673 Answers
SOURCE: my eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Posted on Jun 17, 2008
  • 64 Answers
SOURCE: Eureka Boss - no suction in upright postion
when mine does that I find that the hose is not connected properly where it comes off to use the attachments.
If there is suction there, it is a straight shot to the floor unless it is loose where it fits together.
Posted on Dec 31, 2008
SOURCE: Eureka 4870 vacuum brushroll control doesn't work
Use two hands to presscontroll button upward until it snaps in place.
Posted on Jan 06, 2009
SOURCE: Eureka 2961 BVZ no suction, burning smell
I have the same vacuum. The burning smell is letting you know that your belt is either broken or about to break. I have had mine for a year and have had to replace the belt 5 times. Now I have to replace the brush roller 'cause it broke under normal use. My next vacuum will be a Dyson Ball.
Posted on Jan 31, 2010
pappapumpdaf
  • 635 Answers
SOURCE: My Eureka Optima vacuum doesn't have any suction
It will as long as long as your accessory hose is properly inserted into the base. Otherwise the vacuum stays on the hose only.
Posted on Mar 14, 2010
Why doesn't suction work on eureka
The hoses may be clear but debris could be clogging the point where it is discharged into the bag or container. There also could be a debris clog at the intake.
Sep 03, 2014 | Eureka Vacuums
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Jun 05, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
My eureka vacuum won't suction and starts to smoke when I try to use it. It sounds like it is suctioning when I first turn it on, but after about 20 seconds it begins to smell like burning and does not...
The problem is that your belt is stretched and worn. This causes that burning smell and it also causes the vacuum to not pick up well. You need to replace the belt. Here is the belt you need and the manual with instructions:
Eureka Altima Belt and Manual
Jan 31, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
239 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
