Question about RCA L46WD22 Television
Lost signal & sound
Have camcast cable all wire are installed right was watching tv lost signal for the tv
  • Anonymous Mar 25, 2014
    WHILE WATCHING TV IT GOES BLANK, BUT I CAN STILL HERE THE SOUND
  • 3 Answers
Lso had the exact problem about 2 weeks ago on my L46WD22. Took it to the authorized repair shop and they told me they had others on their shelf for over a month. Since the board has been on back order for a while, my repair shop called and actually got to talk to an engineer at RCA. The problem seems to be a surface mount fuse that RCA said they also could not get. My repair center said that he found a fuse to fit the board, and though it was a higher rated fuse, installed it. TV works fine and it is back in my house, but the repair center is not getting paid for the work they did not fix it!!!
Posted on Feb 17, 2008
I keep getting a blue screen on my Insignia TV. Cable box still shows the channel and I can change channels but nothing on screen. No sound either. This TV is not even 3 years old yet.
A blue screen indicates no video signal, if you change the video input to a DVD player is it still a blue screen? If yes then the TV is defective. If no then some how the signal is being lost to the TV from whatever source you use for watching broadcast TV
Apr 05, 2017 | Televison & Video
I have sound but no picture. How do I fix/
Click on the input button on your remote to make sure you have selected the correct location of your incoming signal. If you are just watching TV and have a digital cable adapter, unplug the power to the adapter and plug it back in. If you have pinched a cable running into the TV and are using a DVD player or other device hooked to the TV you may need to try another cable. If you are using red white and yellow wires for connecting a device try removing the yellow wire from both the device and the TV and substituting with another yellow wire from another device. Also make sure you try additional channels if it's just the TV signal. If you have cable you can also unplug power to the cable box to cycle it off and plug it back in.
May 01, 2015 | Vizio VBR120 Blu-ray Player with Internet...
I have a proscan with no sound so I brought a
You hooked up the sound bar to the cable box red & white sockets, right. Now you have the soundbar hooked up to the TV red and white sockets. Did you notice any difference with the labeling on the two sets of sockets? The cable box sockets were labeled "Audio Out", but the TV sockets are labeled "Audio In"
AV signals are directional. Any socket labeled "Out" will give a signal from it for connecting to another device e.g. the connection from the cable box to the soundbar.
Any socket labeled "In" is designed to accept a signal from something else, but it won't give a signal out. So you can't connect the TV's Audio In socket to the soundbar's Audio In socket because both expect a signal from something else and neither supply a signal out.
Check the back of the Proscan TV. Is there a socket labeled Audio Out? If so, use that.
Sep 03, 2014 | Televison & Video
Lost sound while watching TV on cable. Checked all remotes, nothing helps. TV does have sound for VCR playback. What is the problem?
Likely the tuner in the set which aside from signal also processes audio---also if the set has a headphone jack take a look at that as it could cause this---small but some chance.
My bet is tuner
Nov 08, 2012 | Panasonic CT-36D31 36" TV
Mitsubishi Medallion rear projection lost signal from all devices
Have you fixed this problem yet?. I seem to have the same issue.
Sep 07, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Philips LCD 17PF8946/37 TV not working
The good news is that the "No Input Signal" message means that your TV is not broken. If you are trying to watch cable, then you have simply turned the TV to the wrong input channel. If your cable comes into the Philips using a coaxial cable wire, use the Philips remote to change the channel to Ch.3 or 4 - whichever channel you normally watch cable on. Make sure the cable box is turned on if you have a cable box. If the cable box connects to the TV using another type of wire, use the Ch+/- on the Philips remote and go through all the AV channels until you find the right one. Good luck! Let me know if you need additional help.
-Tha Mp3 Doctor
Dec 30, 2008 | Philips 17PF8946 17 in. HDTV-Ready LCD...
TV IS NOT RECEIVING SIGNAL FROM LAPTOP
Check graphic card software on laptop to make sure it's on the right settings to output image to TV.
Nov 20, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
No sound
A DVI cable does not have an audio connection, along with the DVI you still have to run an audio line from the device (DVD player, cable box, satellite receiver) to the TV. HDMI contains both audio and video.
Sep 30, 2008 | Hitachi 57F500 57" Rear Projection...
I recently purchased a Hawking HSB2 Signal Booster. Two years ago, my son installed a Toshiba Cable modem(PCX2200)and a Belkin Wireless Router(model#F5D7230-4)for Camcast High Speed Internet. The Router...
Booster will only work along with access points in your case the belkin wireless router - you have to connect the device to the router not to the windows xp pc
if you know how to configure and the device are compatiable to each other and allows bridging or can configure as your access point client then you need not wanna to get it connected via wire or T568b standard ethernet cable otherwise you have to connect with this cable will enchance the wireless activity
Wireless signals can go down its strength by any magnetic activity, oscillations such as microwave, powerful steel/metal frames and check your anteena position keep in different direction and check your pc wifi signal strength.
Interlink between your router and booster with utp cables gives you steady flow of data and full band strength.
Aviod using two company devices change the router to Hawking
Thanks Hothawk
Jul 24, 2008 | Computers & Internet
TV signal lost
Have you had a look at the cords? Is there any damage to the hardware itself? Maybe there is something else wrong. Tried running virus scans? I know it's a long shot but it's amazing at what viruses do to your machine.
Mar 24, 2007 | ASUS V9520 Magic/T NVIDIA GeForce FX5200,...
RCA L46WD22 Television Logo
153 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
