Re: How to remove CD from Nagation/DVD 2005 Dodge...
The cover labeled NAVIGATION DISC needs to be removed, top left is an opening where a small flat head screwdriver would help. Completely remove cover and eject disc is on the right.
Interesting problem, perhaps you might try to do a reset of the system initially. Normally, this ought to revert everything back to factory default but of course all user settings, preferences and configurations would also be erased. Additionally, some models/units would also ask for an entry code before being operational, pls have this available if your unit requires one. An alternative method of reset is to remove power from the mains. But again, as a reset and a code might be required.
Could you possibly provide likewise the exact make and model of the Nav DVD-CD?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
There's this website www.reliable-store.com
They have books on ALL vehicles.
it covers
wiring diagrams, electrical diagrams,
fuse diagram, torque specs, PCV, error codes, fault codes, service info, repair info, parts info, owner's/service/repair/parts/maintenance manuals etc everything totally..
I have 1987 toyota 4runner model and I keep servicing and when needed repair it on my own. worth it !!!
You will get your solution and all info on service info, repair info, parts info, wiring/electrical/fuse diagrams, error/fault codes, torque specs, PCV,
it's a very good website for vehicle problems even as old as 1991 ford..
Go to the page below,the 1004 Durango should be the first one listed.
Download that,it's a pdf file.Read it with Adobe Reader,it's free.
If the link below doesn't work,copy and paste this into your browser.
These navigation disks are prone to contamination from dust particles over the years. If the disk is not damaged (scratched), you can try gently cleaning it to see if that works. You can also try a special lens cleaning disc to clear any dust from the reader.
However, if you have you followed all the owners manual instructions for removing it and it won't, you have a much more serious problem with the system. All I can suggest is a trip to a dealer to see if they can help.
For 30 years now,when ever you get any
light on the dash, you have an Emission
System Malfunction ,that has to have the
codes retrieved,diagnosed and repaired
Have you not heard of OBD 2 or read
your owners manual,for any vehicle?
NAV unit uses a DVD disc. If its a copy, it may or may not work. I suggest you remove the NAV disc, unplug the NAV unit from power for 4-5 minutes, reconnect the NAV and try inserting the disc again to see if it reads. If it still does not read, another NAV disc needs to be inserted to verify its not a "bad" NAV DVD disc issue. If it still cannot read the second disc, the NAV unit is bad. The handbook feature needs the disc inserted in the slot 1 of the CD changer unit.
If you remove the unit from the dash the top, take off the top cover, no screws you can acess the CD slot. Remove the 4 screws holding the CD player in place and the ribbon cable and you should be able to remove the CD from the slot.
