posted by RichAP on Nov 30, 2007
When I get my pictures back on a few of them there is a black stripe going across the top of the photo,but other times this does not happen.Then sometimes I get a roll developed and one picture does not come out the negative is blank.Seems to happen in the middle of the roll.
Best Solution
posted on Dec 02, 2007
It sounds like your shutter may be failing.
The N80 has a vertical travel focal plane shutter. This is essentially two curtains that travel across the film plane. At lower shutter speeds, one curtain opens up the shurter, you wait, then the next one travels across, stopping the exposure. At faster speeds, though, they both move together, leaving a small gap between them to let light through.
If the first shutter curtain isn't always making it all the way to the top, this could give you just what you're seeing -- a black band across the top of the photo. One blank negative may well indicate that your shutter failed completely on that shot.
This is something best handled by a camera repair shop. It could possibly just be some dirt in the shutter mechanism, which would be fixed by a good CLA (clean, lube, adjust) ... that's no a bad idea if it's an older camera anyway. However, it could be more than that. It won't be clear which without getting down into the camera itself.
Rating Locked! (?) RichAP has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Nikon N80 35mm SLR Camera
Email this problem
Email this problem
Can you Help with these Film Cameras problems?
The AF-Assist Illuminator
The AF-Assist Illiminator on my... Answer This...
Double Exposure The Easy...
I can set my camera on multiple... Answer This...
Repair Service
Find Film Camera Repairman Near You:
