Question about Panasonic PT-53WX54 53" Rear Projection HDTV
Tv shuts off but power light continues to flash
My TV automatically shut itself off. I thought the kids had done it with the remote. I turned it back on, it turned on then blacked out on the screen and it appeared that the power button was trying to communicate with something. Is there a fuse or something that could have blown?
  • nabil khazem Dec 06, 2007
    when i unplug the the tv and plug it again and turn it on i see some thing on the screen for 1/2 second or less and then i get black tv and the power light flash.
  • jezz62 Feb 10, 2008
    My TV
    automatically shut itself off. I could not turn it back on. I had to unplug it and it comes back on for 1 sec then turns off again and the light flashes again.
    Someone help!!
    Sergeant:
    Champion:
  • 319 Answers
Unit is telling you something is wrong with circuit. LED pilot flashes when malfunction is detected. Power supply shuts unit down to prevent further damage and/or fire. Leave off and seek pro/tech check out
Posted on Apr 21, 2008
SOURCE:
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
TV Turned Itself Off - Now - No Power No Lights Flashing
power supply board is faulty need to check the power transistors and fuses u will need a tech to solve this
Jul 14, 2013 | Samsung HL-R6167W 61" HDTV
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Tv shuts itself off randomly (sleep mode problem)
This is wierd the kids played with your remote and you cannot get it out of sleep mode. Well here is somthing to try. You would take back cover off but here is the disclaimer (HIGH VOLTAGE INSIDE CAN CAUSE INJURY INCLUDEING DEATH) iF YOU NOT QUALIFIED OTAKE IT TO A TECH IF ITS SOMETHING MNOR IT WILL BE DONE WHILE YOU WAIT AND WILL NOT CHARGE YOU OUT THE YANG FOR A FEE. But if you inclined chekc the power supply unit and see if it is giving the correct current to the TV if not replace it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 22, 2009 | JVC AV-20220 TV
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
36 magnavox tv shuts off by itself
MAGNAVOX TV ONLY. 5-10 SECONDS AFTER TURN ON AUTO TURNS OFF-NO LIGHT STAYS ON-I AM FRUSTRATED BUT IT SEEMS LIKE THE OFF ON SWITCH JUST CLICKS BACK TO OFF-ALSO DOES SAME THING BY REMOTE
Jan 16, 2008 | Philips Magnavox MS3652S 36" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Jun 25, 2007 | Philips 27PT81S 27" TV
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
117 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
