Question about Mitsubishi WS-65819 TV
Mitsubishi WS-65819 Sender Board problem
When I turn my Mitsubishi WS-65819 TV on, no picture, just the green light. I had a service technician come out and diagnose the problem, and he said the problem is the Sender Board.
When I turn the power on, I hear a hum, and I can see the TV trying to turn on; the guns all begin to glow...but nothing happens.
Is this a true diagnosis, and can the board be replaced? If so, where?
Yes it can the cost is $350 sumwut dollars ,i got my tv for $54 and thats wut was wrong with it ,the board that is connected to your power cord is wut needs to be replaced sears can do the job but the labor is $200
Posted on Mar 26, 2008
SOURCE:
WS-65819 Shuts off
Yes, remove front speaker grill (pulls off) and inspection plate behind it.
There are 3 large circuit boards as you look from the front---signal to the right, power to the left and Deflection (vertical and Horizontal) in the middle.
What you want to look for is on the middle board any sign of GLYCOL which sometimes leaks from the picture tubes above it.
It is a clear liquid and even tiny amounts can short or stop the board from working; most damage should be in first 3 inches from front of the board----if you find any DO NOT TOUCH IT as it is toxic.
Glycol damage is not uncommon and the first thing you want to look for.
Jan 26, 2012 | Mitsubishi WS-65819 TV
Ws-65819, No response, Not even the blinking green light
To repair damage--you understand the foil at each connection is copper---you have to scrape some of the green coating off near the parts and solder the exposed foil---idea is to solder a wire across any gaps to complete the circuit.
Got it?
SD TECH
Sep 24, 2009 | Mitsubishi WS-65819 TV
Mitsubishi ws 65819
Ur power board ic converter it dead.
Ur Convergence board is bad going to die to.
Both must change.
Aug 15, 2009 | Mitsubishi WS-65819 TV
Turns off as soon as I turn it on. ws - 65819
I had the same problem. The repairman said the Convergence ICs were bad, located on the big aluminum heat sinks on the center board in the TV. He replaces both, and a couple of fuses (that look like resistors).
The tv worked fine for a couple of days then did exactly the same thing. They are coming back out to fix it next week. If there is anything different, I'll post an update.
Nov 22, 2008 | Mitsubishi WS-65819 TV
Mitsubishi 65819
2-1 means no errors, what is it doing or not doing?
May 15, 2008 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 TV Problem
it the circut board that is connected to the power cord ,
Nov 26, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 got Fried by a mouse
Just replacing the board if its the main board is half of the repair. The memory IC which is usually located on the main board holds all the data for convergence,picture geometry,channel memory,color settings etc..So getting it to run is only half of the battle. Got to http://www.partstore.com and look for the main board. I couldn't however look it up because it says your model number is invalid.
Mar 14, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 TV Logo
186 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
