Question about Philips Senseo HD-7810 Coffee Maker
Senseo coffee problem
My Senseo coffee maker does not stop when the cup/mug is full. I have to manually stop the flow. What's wrong and how do I fix it?
Thank you!
  • Smirlex Jan 12, 2008
    My Senseo coffee maker also does not stop when the cup is full, unless I press the off swich.It will empty the entire tank. It worked normally untill the lid stuck shut.
    How does it sense the amout of water that it has pumped?
  • 3 Answers
The pod holder has an O ring to seal the black plastic disc in,if it is not sealed you will end up with more volume and a weaker coffee without the foam,either knock the disc out and try and seat the O ring and then knock it back in or buy a new pod holder,I had this same problem
Posted on Apr 07, 2010
Not enough water coming out of senseo coffee maker
You may need to descale your machine. It is always worth noting that if you put a mug under the machine, it will only half fill it on the one cup setting.
Jul 19, 2014 | Philips Senseo HD-7810 Coffee Maker
Why wont lid on my phillips senseo hd7863 close when the pod is in the holder ?
Maybe you inserted the pod with the wrong side up or you used a 2-cup pod in a single cup holder. If the clamping spring isn't working (the lid feels loose when you try to close it), that spring (that is nothing more than a straight piece of metal wire) needs to be replaced.
Jun 07, 2014 | Philips Senseo HD-7810 Coffee Maker
How much coffee do I use for the 22-cup Farberware coffee pot?
that would depend on the coffee, and how strong you like it.
as well as how large your standard cups are.
I use 1/4 cup of folgers classic blend for 4 'normal' cups of coffee. I also use an oversized camping mug - so 4 normal cups fills two of the mugs. - - - you may want to try 1 1/8 cup of coffee grounds in the filter if making a full pot.
regards,
Oct 12, 2010 | Faberware 12-55 Cup Coffee Urn
My Keurig just started only filling my mug 1/2 full on the large cup setting. I now have to run a full cup option, open and close the lid, and then run the 1/2 cup option to end up with a full cup of...
Have you tried following the descaling procedure given in your owner's manual? The mineral build-up from hard water can cause low flow, and since the machine pumps for a fixed time this means less water in the cup. Descaling usually brings back normal operation.
Mar 06, 2010 | Keurig Elite B40 Coffee Maker
I am interested in purchasing this 6 cup brew station, but all pics I see use travel mugs. Can it be used with regular 10 -12 oz ceramic mugs for home use? How about 6 oz cups that match Corelle...
How does the coffee get into the cup? If it brews directly into the cup then the amount can be controlled by how much water you put into the maker. If it is a 6 cup then it must hold the coffee in a reservoir. Do you have to push and hold a button to dispense the coffee or do you push and wait for it to fill your cup? If it is the latter then it will need to know how large or small the cup size is. Is there a setting for that? If it is a push and hold method then you control the coffee flow so size is up to you. As far as it being a travel mug or ceramic mug as long as the mug will fit in the maker and sit securely under the nozzle then it shouldn't matter what kind of mug it is.
Feb 20, 2010 | Hamilton Beach 48274 BrewStation 6-Cup...
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
One coffee cup button switch not wotking properly after 6 months
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.
if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Jan 24, 2009 | Philips Senseo HD-7810 Coffee Maker
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
How does it make coffee?
You fill it to the line indicating how many cups of coffee you want to make. Then you add coffee to the brew basket, at least 1 full heaping teaspoon per cup. Put the basket on top of the stem and place the stem into the coffee maker. Put the lid on and plug it in. That's it. Don't plug it in without the lid, it's a percolator. It will squirt the water out the top of the stem and it flows down through the coffee grounds.
Aug 09, 2008 | West Bend (58036) 36-Cup Coffee Maker
Senseo coffee maker
Having dismantled and inspected several of this "strange machines" my conclusion is the following:
There is an oscillating-piston pump inside with in- and outlet valve.
It is energized by a microprocessor controlled circuit for a working time depending on the button selected (1 or 2 cups). The pressure and flow are nearly constant for a perfect working pump.
The pod holder restricts the thruput by its central hole. (E.g. you get now an extra pod-holder with a very small hole for expresso type)
So if you don't get enough coffee it may be that
1) the duty-cycle (timing) of the pump has changed.(not often occurring) no repair, you have to undergo electronic and programming work
2) the pump lost efficiency (cylinder of the pump clogged, piston not working with complete stroke, spring force fadening or just one of the 2 valves leaking) ca be "repaired" after dismantling machine ,extracting pump and taking it apart, success not garanteed - grinding valves is already time spending
so my principle before starting this work is to run the machine without the coffee pod to check the water output, use a new holder with clean central hole, if this works it will be nr.
3) the central hole of the holder is clogged, may be not by limestone, but dried coffee extract (grease) clean with needle or even better with micro-drill
Aug 10, 2007 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo HD-7810 Coffee Maker Logo
334 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
