Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sound picture remains but the sound shut off. TV is brand new just set up today(SHARP AQUOS).also hooked up new HD motorolla box.
    Problem Solver:
  • 17 Answers
You may want to check to make sure that the tv output select (Menu > Options > Output Select > enter ) is set to fixed and not variable. Also. bypass the HD box and run the coaxial straight into the tv from the wall. If you have sound chances are you need to reset your cable box.
Posted on Dec 31, 2007
  • 71 Answers
This hapen only on HDMI conection. Try to update the firmware, but beeing in warranty you should call an authorized tech. If your from Montreal area I can do it for you.
Posted on Dec 06, 2007
SOURCE:
Sharp aquos dolby digital tv has sound but no picture
go to source on your remote then click down to the second one like HD ONE.
Feb 21, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Dec 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Finding a set top box
Do you mean a freeview box? if so any freeview box will work via thw scart.
Nov 04, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos TV will not display contents of DVD using Microsoft Media Player 11
it sounds like a problem within your vga connection on the tv check around and see if there is some firmware for this fix or right click on your desktop were there is no icons and select properties select settings tab and set ur display as needed.
C
Oct 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv shutting off
it sounds like it may be a capacitor problem and it may be linked to the electricity you receive adding a battery back up of sufficient quality will smooth out the electric current and also **** up the spikes from the power and light company. I have seen many aquas suffer from capacitor failure but it may be an expensive fix.
check your electric output and see if it can handle the load for this tv.
Apr 28, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC46D64U
No reason for the audio not to work on the RF cable. Check under menu and option and make sure audio is set to fixed and not variable.
Jan 08, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Oct 07, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
183 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
