Question about Acer AL1913 19" LCD Monitor
No Signal problem
Ok this is the problem, heres the story
one day i started up my computer and so it would freeze after about 2 minutes. So i put it in safe mode and i found a trojan so i deleted it. It fixed the freezing problem but now my monitor finds no signal even though every thing seems to be tight in. (This has happened during the freezing problem, sometimes before it freezes i turn on my computer and there is no signal and i cannot even see anything. then i fixed freeze and this reaccured)
whooo...
thank you ahead of time.
  • 180 Answers
Your lcd need a tech who could help you to repair the power failure.
Posted on Apr 22, 2008
LG Monitor worked fine. I put it to sleep I started my computer later that day and monitor has message -D-SUB No Signal Will to into save mode shortly.
No mystery here, if you can read "-D-SUB No Signal" then it's just your LG Monitor letting you know that everything is OK with it, but you still might want to unplug your computer so it will properly wake up from snoozing. Sorry to tell you this, but it will probably happen again. So turn off that sleep feature as recommended by screen experts. Remember this feature was concocted more than 30 years ago for computer monitors that have long since been discontinued.
Oct 09, 2017 | LG Computers & Internet
Why is my Humax 4000 very slow, freezing and scrambled saying bad signal.
Check the signal level and quality. Reseat all aerial connections.
Jun 18, 2016 | Humax Televison & Video
How i uninstall deep freeze software
HI Good day!! do the following
Disable Deep Freeze before uninstalling it.
To disable Deep Freeze:
1. Hold down the shift key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6.
2. Enter your password and click OK.
3. If you have not yet entered a password you should be able to click OK without entering a password.
4. The Boot Options dialog is displayed. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
5. Reboot your computer. After the computer reboots, you are ready to uninstall Deep Freeze.
To uninstall:
1. Locate the installation file you used to install Deep Freeze on your computer. By default, the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
2. Run the installation file (DF5Std.exe or DF6Std.exe).
3. Select the option to "Uninstall"
Deep Freeze is uninstalled and your computer is rebooted.
Oct 12, 2010 | Computers & Internet
My computer keeps beeping when I turn it on!!!
OK.
Thy to identify RAM, remove it and clean the contacts with a rubber (the same you use to erase the pencil marks).
Put the RAM again and try to boot.
Another problem can be the temperature...
Remove the fan (and clean it)
Remove the heatsink (and clean it)
Put new thermal compound
put back the heatsink and the fan (connect the wires)
check your temperature in your BIOS
Best Regards
Jun 29, 2009 | HP Compaq WF1907 Monitor
Games, video keep freezing
your vc might be heating up, try to remove it agai. take the heatsink out and then put a thermal paste on it before returning it on the vc, then install it again and see if that will works.
Apr 07, 2009 | Computers & Internet
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Inspiron B130
Well start a bit slower then.
go into the bios at startup F2, and navigate around does it freeze there. if no then
start windows in safe mode F8 when windows logo shows.
freezing ?
If its not freezing then turn off the startup programs.
Start/run/msconfig and then uncheck load startup items
and start normally, click the dont show me this again /ok
any freezing.
If its freezing you may have a hardware issue.
if you have 2 sticks of memory remove on and or /reseat them
boot the dell diagnostics cd and check the cpu and memory.
report back
Jan 30, 2008 | Dell Inspiron B130 Notebook
Dvd/cd drive
remember only one can burn at a time
Jan 12, 2008 | Intel Everex LM7WE Notebook
Acer AL1913 19" LCD Monitor Logo
133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
