Question about Linksys WUSB54GS 802.11G USB Adapter Wireless-G With SpeedBooster (Retail) (NTUSLSUSB54G)
Signal strength Hi my mother lives across the st. from me w/ the linksys router . I have the wireless linksys usb but i get little or no signal at all can you please help me? thanks Weak in O.C
    Problem Solver:
  • 13 Answers
An omni directional antenna connected to the router will extend the range of your wireless network, it should solve your problem. You can find them in any PCs store.
Posted on Nov 30, 2007
SOURCE:
I have the router right by my PC, it appears connected but no signal strength at all (no bars) what is wrong?
try changing the wireless channel on the router and see if that makes any difference.
Open the setup page of the router.
Go to wireless tan and change the standard channel to 11. save the settings.
You can also try updating the drivers of the wireless adapter on your computer.
If your router is too old then you must upgrade the firmware on the router.
See how to upgrade Linksys router firmware
Mar 21, 2012 | Linksys Wireless-G Broadband Router
Unable to stream novie sites with my linksys wireless-g router
Check the connection (signal) strength of your wireless connection in the status area of the task bar in Windows. Also, hovering the mouse over the wireless connection should reveal the connection speed. 54mbps is the highest you can expect on a wireless connection, which is generally OK for streaming video..Any less of a signal strength/connect speed will likely not be adequate for streaming video.
A poor signal strength is usually because of too much distance or too many walls between the router and the computer.
Hope that's helpful.
Jan 15, 2011 | Linksys Wireless-G WRT54G Router
Low signal strength
Having many users connected to a single WAP (wireless access point) will not affect the signal strength. It will however, affect the speeds each user is capable of.
Most Linksys routers have a homepage address of 192.168.1.1 - Enter this in your web browser.
From there you will be able to find wireless settings and enable either a password or a WEP key for security.
If you found this helpful please leave feedback.
Feb 05, 2010 | Linksys Wireless-G WRT54G Router
I have a Linksys router since 7/09 but keep losing
LOSING WIRELESS CONNECTION ?
Make sure the latest wireless card driver is installed in the computer.
Locate the wireless router higher and away from concrete and brick walls, foil insulated walls.
Locate the wireless router away from cordless phones and microwave ovens these can cause interference.
You could be getting interference from other wireless access points or wireless routers in your area. Check the wireless broadcast channels in your area, and select one that is unused or one that has the weakest signal strength.
Jan 22, 2010 | Computers & Internet
How do I increase the IP range in a Linksys WRT150N?
Get a surge protection power board and connect your computer equipment and wireless router to this power board.
You can configure the wireless router to a different channel, one that is not used by your neighbours so that the wireless signal won't interfer with each other.
Have a look at the signal strength to your computer, if it is weak then move the router away from concrete walls and/or raise it higher to improve the signal strength.
Sep 26, 2009 | Linksys Wireless-N WRT150N Router
Vista wireless connection to belkin-n
It sounds like your linksys is your main connection so therefor it will not always let belkin connect because your pc has registerd your linksys to be your connection.
Sep 20, 2009 | Belkin (F5D5231-4) Router
Would a neighbors linksys router interfere with my belkin connection?
do check the signal strength of the wireless connection..you can improve signal by removing any big objects between the compu and the router/access point and/or re positioning the router.also intervening walls will affect signal..the fact that you are getting a linksys signal impilies that your home network signal is weak..hope it helps!
Oct 29, 2008 | Belkin (F5D8231-4) Wireless Router...
Linksys WUSB300N adapter not detecting wireless links
I am confused, you are using 2 routers, or you using their dsl modem/router? or your original??
Dec 29, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Open Questions:
See all Linksys WUSB54GS 802.11G USB Adapter Wireless-G Questions
Computers & Internet Logo
82 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
