Question about Nokia 7373 Cellular Phone
Nokia power jack
My phone power jack pop out I want to find out if i can replace it ?
    Problem Solver:
  • 16 Answers
It can be replace quite easily if you contact a shop near you that repairs mobile phones. i work in one such shop in the north east
Posted on Dec 10, 2007
SOURCE:
My mobile nokia model 1209 is not charging
Mostly nokia chargers doesn't make problems...
just try the following..
1.connect ur mobile with a system (usb cable)...if it charges then replace your charger fault is in their,
2.if problum not solved then,power off mobile,romove the back flip and remove the bettry,check the phone,s connecting metel terminals,
if they r slightly bent,bend them slightly upward whith the help of a pin,check metal terminals of the battry if they r ok then good othervise replace bettry with new one.
3.check the bettry in another cell phone if it charges theno problum is in ur cell phone or power jack(socket)...
IF Charging Problem not Solved So then contect a qualified repair.
Aug 29, 2013 | Nokia Lands Phones
My nokia 2760 not powering and not charging
First Option:
mostly nokia chargers doesn't make problems...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 12, 2012 | Nokia 2760 Cellular Phone
Nokia 1202 not charging
First Option:
Second Option:
Oct 09, 2012 | Nokia 3110 Cellular Phone
My sony ericsson k800i does not charge
First Option:
Second Option:
Aug 20, 2012 | Cell Phones
HOW TO CHANGE CHARGING JACK OF NOKIA 1650 HAVING NO PRINT...... ITS URGENT
NOKIA 1650 JACK EAR PHONE PRINTS LOSE ,, SOLUTION IT IS URGENT
Jan 04, 2011 | Nokia 1650 Cell Phone
Nokia 1112, not charging
First Option:
Secend Option:
Aug 30, 2010 | Nokia 1112 Cellular Phone
Test mode on nokia 1200
Test mode is used by engineers to repair particular problems with mobiles. It would appear you would need to take this phone to a mobile repair centre and get them to fix the s/w on it.
May 25, 2009 | Cell Phones
Enhancement not supported??
It is either Software or Hardware - both solutions below... best of luck
SOFTWARE
Just in case this setting got mixed up, go to menu - tools - settings - general - enhancement - and make sure your default is set to "Headset". If it is already set to "Headset" then it may be a hardware issue...
HARDWARE
The Nokia detects a 2.5mm jack when inserted and defaults to the standard headset mode (sound comes out through the headset but uses the phone speaker). There could be 2 causes to this (1) short in the headset jack or (2) debris in the headset jack that is making a connection between the contacts.
I recommend that you use a "can of air" sprayed directly in the jack to clear any debris. If this does not work, plug in the phone/headset jack that came with it and ensure that it detects it.
If that does not work, it is a short and you should return it or, if it is out of warranty, get someone skilled to replace or disable the jack (only do this is you have no other option -- Nokia won't touch it after you open and solder it).
Feb 09, 2009 | Nokia N73 Cellular Phone
Power jack
HUH?!!?!? ... If you take it to a Verizon corp. store it shouldn't cost no more then 50 bucks to replace so long as it's not liquid damaged and within 2 years of purchase date.
Whoever told you 200 bucks was about to pop open your phone and play bar room mechanic on it. Cell phones these days are no long the "pop open and fix em " types ... You do more damage to a cell phone opening it up and trying to fix anything. Hence why all manufacturers now just replace broken electronics ... NOT "fix them"
Hope this helps.
Dec 05, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Nokia 7373 Cellular Phone Logo
83 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
