Question about Emerson Smartset Clock Radio
Running clock The numbers and dates on my clock are continuously running, (changing). I can't get it to stop. What do I do???
You might try changing the timezone to something else and then back again. It sounds like it is unable to read your timzone. you can also try moving to a different location in the house to see if it will set, and then after it has correctly set the time, move to where you wish to setup.
Posted on Dec 29, 2007
How doI set the clock
Setting the Time (Without Date Display) If your vehicle has an AM/FM base radio with a single CD player and preset buttons numbered one through six, the radio will have a clock button for setting the time. You can set the time by following these steps: 1. Press the clock button until the hour numbers begin flashing on the display. Press the clock button a second time and the minute numbers will begin flashing on the display. 2. While either the hour or the minute numbers are flashing, turn the tune knob, located on the upper right side of the radio, clockwise or counterclockwise to increase or decrease the time. Instead of using the tune knob, you can also press the SEEK, FWD (forward), or REV (reverse) buttons to adjust the time. 3. Press the clock button again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing will stop after five seconds and the current time displayed will be automatically set. To change the time default setting from 12 hour to 24 hour, press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H are displayed, press the pushbutton located under the desired option to select the default. Press the clock button again to apply the selected default, or let the screen time out. Setting the Time (With Date Display) If your vehicle has a radio with a single CD player or a CD with DVD player, the radio will have a clock button for setting the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the clock button and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) will appear on the display. 220 3. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. If your vehicle has a radio with a six-disc CD player, the radio will have a MENU button instead of the clock button to set the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the MENU button. Once the clock option is displayed. 3. Press the pushbutton located under that label. The HR, MIN, MM, DD, YYYY will appear on the display. 4. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the MENU button and then the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. 221 To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year, follow these instructions: 1. Press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) are displayed. 2. Press the pushbutton located under the desired option. 3. Press the clock or MENU button again to apply the selected default, or let the screen time out
Nov 10, 2016 | 2007 Pontiac Torrent
Date and time arror
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
May 14, 2014 | Samsung SCX 4521F All-In-One Laser Printer
My emerson cks1850 still stuck to the old daylight savings time and I need to fix it as i rely on it for work and frequat power outages we have were i am and the auto reset is why i like it but now it...
unplug the clock radio from the power, take out the back up battery ( if it has one). let it set for 60 seconds or so, plug it back in, It should now be flashing 12:00 over and over. now reset the clock to the correct time and date.
Mar 14, 2011 | Emerson SmartSet CKS1850 Clock Radio
How do you change the clock on a 2009 Chevy cobalt.
Setting the Clock Without Date Display AM/FM Base Radio with a Single CD Player
To set the time:
  1. Turn the ignition key to ACC/ACCESSORY or ON/RUN. Press to turn the radio on.
  2. Press until the hour begins flashing on the display. Press a second time and the minute begins flashing on the display.
  3. While either the hour or the minute numbers are flashing, turn to increase or decrease the time.
  4. Press again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing stops after five seconds and the current time displayed is automatically set.
To change the time default setting from 12 hour to 24 hour, press the button until 12H or 24H is displayed. Once 12H or 24H is displayed, turn the knob to the desired option to select the setting. Press the button again to apply the setting, or let the screen time out.
With Date Display Radio with CD (MP3) and USB Port, and Radio with Single CD (MP3) Player
To set the time and date:
  2. Press and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) displays.
  3. Press the softkey located below any one of the tabs that you want to change.
  4. To increase the time or date do one of the following: • Press the softkey located below the selected tab. • Press SEEK, or FWD. • Turn clockwise.
  5. To decrease the time or date do one of the following: • Press SEEK or REV. • Turn counterclockwise.
The date does not automatically display. To see the date press while the radio is on. The date with display times out after a few seconds and goes back to the normal radio and time display.
To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year:
  1. Press and then the softkey located below the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) displays.
  2. Press the softkey located below the desired option.
  3. Press again to apply the selected default, or let the screen time out.
Nov 21, 2010 | 2009 Chevrolet Cobalt
I plugged in my Emerson Smartset Clock Radio (model CKS2005) and the date is off by a couple. Today is August 4, Thursday, and it states August 7, Saturday. How do I change the date? The date button is...
You have to run the clock back. Press Time/Date and then press up or down after you run it 24 hours the date will change, and the date will move day to day.
Aug 05, 2010 | Emerson Smartset Clock Radio
The clock sticks on a number and stops on that
these is clock circuit defective, needs to be repaired
Jan 08, 2010 | Audio Players & Recorders
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
Emerson Smartset Clock Radio Logo
53 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
