Question about Electrolux Guardian Bagged Canister Vacuum
Twenty year old Electrolux canister swith stopped working
How do I take the sweeper apart so I can replace the switch
  • Jay65 Feb 04, 2008
    We have the same problem with an old electrolux canister sweeper. The power switch on top of the canister is not working and I can't find any screws to open the top of the canister. Maybe the housing clips together somehow. I don't think Electrolux wants you to take the sweeper apart.
  • Anonymous Mar 16, 2014
    I have an Electrolux Ergo rapido ultra 12. It is 1 1/2 years old and the charger is no working.
  • 75 Answers
What switch? If the switch is inside the tank, open it from the underside with 3 screws.
Posted on Jan 14, 2008
How do I get at, and then repair or replace a not working on-off switch of an electrolux ambassador?
You should take it to your local vacuum shop and have it serviced. This is not an easy switch to replace. First, you will likely never figure out how to take it apart, and second, if you do, you will likely never get it back together correctly. Trust me, I've been repairing vacs for over 26 years. This is one you will be wise to spend a little bit and have a proffessional do it.
Dec 25, 2014 | Electrolux Vacuums
I have an old AP 200 Electrolux Canister Vacuum cleaner. Can,t figure out how to take it apart to check the main switch & motor. What is the trick to getting it apart?
The whole thing comes apart like a puzzle. The side rubber pieces on each side slide outward to front of machine. After they are removed everything comes apart. Make diagrams so you will not forget how to put back together. If you need any more help, let me know. GOOD LUCK FRIEND.
Sep 12, 2014 | Electrolux Vacuums
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
The sweeper part is on, but the canister part is not
The problem is most likely the switch. It could be a bad/worn switch, or simply a broken wire or bad connection to the switch. An easy fix at an authorized Electrolux service center.
Oct 16, 2010 | Electrolux Vacuums
Bad bag sensor
yes it is very simple to take apart and replace. for screws on the bag door and then it is only 3 wires to pull off of old switch
Apr 01, 2010 | Electrolux Guardian Bagged Canister Vacuum
Have an electrolux 2100 canister vac, it has lost suction power thru the years. no clogs in newer hose or in sweeper. even with new bag, filter and belt only increases power minimally.
Have you ever over the years replaced your brushroll ? Have you tried dropping a coin thru the hose from one end to see if it comes out the other end ? Have you taken the wand loose from the elbow ( the swivel part of your carpet sweeper) to see if there was a blockage ? Does the motor make a strange noise ? Have you ever had a tune-up on your vac.
You might think about taking your vac to your Aerus/Electrolux shop.
Joe
Nov 19, 2009 | Electrolux Vacuums
Electrolux Canister - Stops working after 1-2 minutes.
Electrolux Canister - Stops working after 1-2...
Our vac works for a short time, then shuts off and makes clicking noise as if trying to restart again. Works after cooling for a while but for another very short time. Your suggestion on fix would be greatly appreciated.
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure
I would advise that it could be a thermal switch or a regular switch that the thermal switch is over heating and needs replacement – there are small hoses in the door section that could have been pinched or kinked and it stopping the air flow from the vacuum – also check for a clogged or plugged vacuum hose, a full vacuum bag or a dirty vacuum filter. Check the thermal switch or reg switch or the hoses in the door. Or feel free to contact your local vacuum dealer in your area or in the yellow pages, or call the factory @ the phone number listed below:
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Don – The Vac Man
Apr 21, 2008 | Electrolux Guardian Bagged Canister Vacuum
No Power coming thru hose handle
It probably wouldn't help, it sounds like the switch. Have you tried pushing the reset button? (It's a little red button on the end of the power nozzle.)
Feb 24, 2008 | Electrolux Lux 5500 Canister Vacuum
Eleectrolux canister sweeper power switch
There should be screws holding the handle asembly on to the top. One near the from, another by the handle, then slide the door near the back, there are 2 more screws there. with the handle off, you can get to the switch. Hopefully you can fina a replacement, alot of parts for the older Electrolux is No Longer Available.
Feb 12, 2008 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
392 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
