Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Stem broke off my Flash drive
I accidentally tripped over my laptop power cord knocking the computer onto the floor and bending my flash drive. The stem broke cleanly from the rest of the drive, I was wondering if it can be sautered back on? Or repaired in some way.
  • tedthehobbit Jan 16, 2008
    I was sitting in a swivel chair and my knee accidentally bumped the usb connector out of the flash drive body! What should I do! :( I am like crying! Please!
  • Ms_Anonymous Jan 21, 2008
    I have the same problem. My USB port/connector of my SanDisk 1gb black cruzer micro flash drive broke off. I was told soldering should make it work but I can't take out the white plastic part of the flash drive to do so. Is there any way I can get it off or any other place I can get it fix for a cheaper price preferably under $50 or less if possible?
I had this exact thing happen...I contacted SanDisk and they had me send it to LC-Tech. They have a deal worked out with them for $75 up to 1GB and $125 over 1GB. I sent it and within 24 hours they got the data off and sent it back to me. Here is the website link: http://www.lc-tech.com/services/sandisk-recovery.html. Good Luck!
Posted on Jan 15, 2008
    New Friend:
  • 20 Answers
Understanding this is an old thread, I'm sure people will still find it looking for help. Therefore, I will add this to it. This is a very common problem. The first thing that should be remembered is that the fix for this is SOLELY for the purposes of getting the data off, and not to continue using the same drive. If you do not posses the technical skills and tools to micro solder it's best to contact a professional who can fix this for usually under $199. SERT Data Recovery is a reliable company that fixes these problems every day and actually has regular specials running. Other companies like DriveSavers and KrollOntrack are usually considerably more expensive. If you do feel confident with a soldering iron and there is no other physical damage to the PCB board then you can always solder an old USB cable to the board to get your data off. You do of course risk losing your data permanently if you do this the wrong way.
Posted on Feb 02, 2014
Falling Down,
Could you fix this for my USB drive?
Thanks,
Mark
momotram @ hotmail dot com
Posted on Dec 15, 2007
    Scholar:
    New Friend:
  • 67 Answers
If you can see bare copper at the break area, you may be able to repair it with soldering by bridging across the broken spot with small bare copper wires soldered between the breaks. Strip a multiple strand wire and use solder flux to clean the board and wires. Use hot-melt glue or epoxy to hold the parts together.
Posted on Nov 30, 2007
  • Marshall Smith
    Marshall Smith Nov 30, 2007
    If the board is covered with soldermask (usually green or blue film) remove it with an xacto knife before soldering.
I have an acer laptop 5532. My someone tripped over the cord and pulled it off the table onto the floor. Now when I turn it on all I get is a black screen. Can it be easily fixed or should I be shopping...
Well there might be several problems but I hope if there are no serious damages visible then it might be worth to repair. Probably laptop has been accidentally disconnected from screen so I recommend you to go for any laptop repair shop and ask them for solution. Tell them what do you think it might be and they will sort problem for you. If screen is not damaged then there might be only connectivity problem which is easy to repair even yourself. In my mind there is no reason to buy new laptop
Oct 25, 2010 | Advent Netbook
Hello, I tripped over the power cord and the Acer Aspire One fell to the floor from the fireplace so about 3 1/2 feet. Now it will not show anything on the screen but green power light does come on and if...
My thoughts is that one if not a couple of the PC boards inside is cracked or broke. More than likely you broke the inverter power board which lights up your display.
May be a time for a new laptop. Would cost more to repair than to buy you an new laptop.
My thoughts is you may find another one on E-bay that has some minor issues or in need of a hard drive and you could take the hard drive out of yours and put it in the new/used one.
Blessings,
A/V Media Guy
Nov 23, 2009 | Acer Aspire One Netbook 8.9" Notebook
I bent the metal usb connector on my 4gb cruzer and the light flashes one time and system wont recognize device.
I had the same situation happen to me. My flash drive was in my computer on my coffee table and my dog tripped over the power wire for the laptop and it hit the floor bending the flash drive to about a 22 degree angle. I gently grasped the metal portion that inserts into the usb port and slowly bent it back to the original position and it worked fine. Two weeks later my dog ate the damn thing!! If you attempt to bend it back, make sure that you do not use pliers or any tool that may crush the metal portion or bend it out of shape. If you have an old computer or a usb port on a wire or hub, insert it, and bend it by hand. Good luck and I hope this helps.
Oct 26, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I dropped my laptop and my memorex travel drive bent. When i carefully pulled it from the usb port the memory card came out of the plastic casing a little and the stem broke. I tried to bend the card back...
If you are good wih a fine tipped soldering oron or know a person who is then there is a slim chance you can repair it.
But be prepared for the worst.
Oct 12, 2009 | Memorex Electronics - Others
Need replacement for lakewood box fan power cord
Use some needle nose pliers on the prongs and bend them back. They will be fine unless they broke off.
Aug 30, 2009 | Lakewood HV 18-c Floor / Box Fan
Laptop fell onto floor...now my memorex travel drive is broken...all college papers lost...help
This is actually fairly common, if the laptop still works with the broken USB socket you can take the cheap approach which is just don't use that port. If you need more ports a USB hub is pretty inexpensive.
Nov 27, 2007 | Electronics - Others
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
1,778 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
