Question about Canon DC100 DVD Camcorder
AV jack Hi - When I plug the AV jack into the camera and then into any of my three tvs i have audio but the tv screen just shows a distorted black screen. the screen on the camera is fine but i cannot watch the video on the tv. im using the av cord that came with the camera....is it just a bad cord? Thanks
    Problem Solver:
  • 7 Answers
YES YOU MAY EITHER WANNA REPLACE THE AV(STEREO VIDEO CABLE) OR IF U HAVE HAD IT LESS THAN 90 DAYS CALL CANON FOR A REPLACEMENT 800-828-4040
Posted on Nov 30, 2007
SOURCE:
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
HOW TO SET UP REMOT TO VIDEO CHANEL,I CAN,T CHAN THE CHANEL TO THE VIDEO CHANEL
Hello
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
ON.
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
screen.
5 Press the PLAY  button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
jacks.
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
OK
Jan 06, 2011 | Philips 20PT633R 20" TV
Tv only accepts signal from the single black cable cannot get the tv to recognize the 2 audio cables and one video cable.. how do i fix this?
Hello
Your Emerson TVs audio format is not stereo; it is mono. Therefore only one audio input will be active. There is a Note give on your TVs manual. I copies it here for your information.
1. VIDEO (IN) jack- Connect to the video
output jack of a video camera or VCR.
2. AUDIO (INPUT) L/R jacks- Connect to
the left/right channel audio output jacks of
Note: The AUDIO (INPUT)L jack is for
mono input. The sound is heard from both
speakers. Use this jack for monaural audio
equipment to be hooked up.
OK.
Dec 21, 2010 | Emerson EWF2004 20" TV
Manual for samsung es65 camera I would like to view my pictures on my samsung TV I was told I could do this direct from the camera to the TV just by using the a/v cable Is this correct and if so what ports...
You can download a user manual from here:-
http://downloadcenter.samsung.com/content/UM/201002/20100202195655453/ES65_ES67_English.pdf
You should have a AV cable with the camera, that has 1 round plug at one end and 3 round plugs at the other.
The single end plugs into your camera, there is a socket on the side marked AV. The three plugs at the other end go intot the TV.
They are colour coded (White - audio left, Yellow - Video and Red - Audio right) you need to find three sockets on your TV which match. Once connected and a slide show running on your camera, select one of the AV tv channels on your tv remote control.
If there isn't the 3 colour coded sockets on your TV, there probably is a couple of SCART connectors on the back (Big black socket with about 20 holes) You can buy adaptors, from electrical stores, which convert your AV cable out to a scart. Its just a box with the 3 coloured inputs and a scart output.
Jul 03, 2010 | Samsung Cameras
After connection my pc to the tv, how do i get my screen on my pc to show on my tv....i pressed f5 and it's not working it keeps restarting my movie on the pc instead of it showing on the tv screen
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Feb 21, 2010 | IBM ThinkPad T41 Notebook
Bush LCD tv wont allow Wii to be tuned thru AV
Hi, the av lead with the three connectors at the end make sure you have them connected correctly -
Yellow - Video
White - Left Audio
Red - Right Audio
It's a simple mistake to make , but check it.
Let me know - Anthony
Feb 10, 2010 | Televison & Video
How can I hook this cam up to my Television?
For this camera you will need to find in your equipment (or purchase) a "stereo video cable "
This cord features a 1/8th (male) headset jack on one end and 3 male RCA jacks on the other. (yellow/red/white).
Plug the 1/8th jack into the camera's AV input and the RCA plugs into your TVs RCA port input and select the correct AV input (AV 1, 2, etc)on your tv selector and the camera should play through your tv.
Nov 04, 2009 | Canon ES75 Camcorder
Connecting portable dvd player to tv
You should be able to connect the portable DVD player to the TV using an audio/video (AV) cable. The type of A/V cable you need depends on the receptacles on the DVD and the TV. Some older units have only one jack for audio and one for video. Newer units have one jack for video and two for audio. Matching the color coding of the cable, plug one end into the A/V out jacks on the DVD player and the other end into the A/V in jacks on the TV. I hope this solves your problem.
Apr 07, 2009 | Televison & Video
Jvc av-27730 27"
One thing you should not do with electronic devices which have a start up proceedure is to turn the power off, and then on again without a wait of about five minutes. Some equipment manuals warn you about this, and specify a longer period. The start-up has to have time to reset. It will be more likely to reset if you do not leave it on standby, and even unplug it. In your TVs case you need to describe the distorted picture as it may give a clue to a fault, or incorrect start-up. The horizontal line indicates the frame timebase had stopped working. No picture could be a fuse blown inside the set, or a timed cutout which may reset after a time. Try after several hours to see if it comes on. If it is just the frame timebase (vertical) it is worth repairing.
Oct 22, 2006 | JVC AV-27230 27" TV
Canon DC100 DVD Camcorder Logo
100 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
