Hi, I have a zanussi turbodry 1200 which is around 2 years old. My
wife tells me that everything works fine until the machine trys to
enter the spin cycle. The drum starts to rotate then cuts out after a
second or two. It then attempts to spin a couple more times then gives
up. (Know how it feels). Any advice would be gratefully appreciated.
its very common for front load washers to have the water pump to freeze up.
ever washed something with sand or little rocks or rubber bands?
flip the washer to the side, then locate the water pump. take the filter and the hoses around the water pump. sometimes the water pump too, to make sure that the fins on the water pump are free and not stuck. put everything together and try the cycle. when the water pump is stuck it will cause the error and will not go into the spin cycle.
a tripswitch went in my fuse board while my washer was mid-cycle. i flipped the fuse switch back on,...
(More)
a tripswitch went in my fuse board while my washer was mid-cycle. i flipped the fuse switch back on, but now the washer won't start another cycle... any ideas?
The belt connecting the motor to the drum of my Zanussi 1219 Washing Machine keeps coming of. The...
(More)
The belt connecting the motor to the drum of my Zanussi 1219 Washing Machine keeps coming of. The belt has not snapped and doesn't seem to be badly worn (though I'm not an expert so don't know)! Should I buy a new belt and how do I ensure that I replace the belt properly if this is the problem. Cheers, Colm
i have a zanussi washer/dryer it washes fine but when you put it on dry it drys for about 15 mins...
(More)
i have a zanussi washer/dryer it washes fine but when you put it on dry it drys for about 15 mins then e20 comes up if you switch it off and start again sometimes it will dry without stopping :( someone please help......................................?
My fabric softener compartment dispenses, but fills up with water after every load. Any solutions on...
(More)
My fabric softener compartment dispenses, but fills up with water after every load. Any solutions on this?
My Zanussi Diplomat APM8702 will not start. When the 'on' button is pressed the red 'on' light...
(More)
My Zanussi Diplomat APM8702 will not start. When the 'on' button is pressed the red 'on' light flickers but will not fully light up. Someone on the message feed mentioned replacing the circuit board but doesn't say how. Any ideas?
