Question about Maytag PTB2154G Top Freezer Refrigerator
Freezer and Refrigerator section stopped working
Started with water leaking from the Freezer down through the Refrigerator. Freezer started to stop freezing items. The next day the Freezer was not making ice cubes, just water in the ice maker and the refrigerator stopped cooling the food.
  • 1 more comment
  • Anonymous Mar 06, 2008
    GE Mod TCX18PACBWW two door refrigerator with freezer on the bottom. Water leaks out of the freezer door. There is a drain hole in the top rear of the freezer. Ice is under the hole and an ice path goes to the front of the freezer and water drips out the door. This appliance does not have a drip pan under the unit. The unit is about eight years old and did not have this problem before. Thank You
  • Anonymous Mar 20, 2014
    freezer stopped working but frig works but not as cold
  • Anonymous Mar 28, 2014
    Icemaker also stops making ice
  • 83 Answers
Check your drain line and check defrost system, defrost thermostat, heater, and timer
Posted on Nov 30, 2007
My refrigerator has water leaking from the freezer into the main refrigerator compartment. How can I stop that?
Ok, you have too sources of water in the freezer section. one from the ice maker if you have one, other is defrost. Either one can cause this, check the drain under the evaporator, most likely the drain is obstructed and the water has no where to exit so it builds up and drains into the lower section (gravity). Te drain can be found under the evaperator behind the false wall in the freezer section. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jan 15, 2015 | Whirlpool Refrigerators
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Sub zero 561, evaporator is icing. 1st tech came in and after checking gas pressure told us that evaporator is leaking. we called in secong tech, he filled up gas and it started cooling fine but couple...
It may be leaking but I think more likely is that you have a problem with the defrost system and it is not defrosting properly... that can give the same symptoms as a low charge or leak condition...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Sub-Zero 561 / F
Kenmore bottom freezer refrigerator warming up
Hi
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Regards
Berry
Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Jan 07, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Automatic water dispenser not working/bypass valve leaking alot
Dear Rodeo mary,
Before you do anything else, please first defrost the fridge. Yes, turn it off and leave it open for a couple of hours until all the ice in all compartments has melted. Clean it and put it on again. Is it ok ? Please let me know.
arturocruz.
abwakhweya@yahoo.com
Jun 02, 2009 | KitchenAid KBRP20ERSS Stainless Steel...
Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Freezing fine,food area warm
I have the same refrigerator and the SAME problem. The freezer unit didn't work at first (for about a week) and then it started freezing solid with not way to control the temp. When that happened, the refrigerated section stopped working and has not worked since (two months). Help!!
May 27, 2008 | Frigidaire FRT21H8 Top Freezer...
Leak from icemaker shorts electricity in house
It sounds like the ice in the bin is warming up enough to melt for some reason then re-freeze. Check your door gasket seal and also the ice chute door flapper seal to make sure warm room air isn't being drawn into the ice bin area. Also make sure the freezer area is VERY cold like 0 degrees F or lower, that will keep the ice hard and help stop the ice from having a liquid surface film from opening and closing the freezer door too often (then freezing again). The water down the back is from the ice cubes melting a little then re-freezing. Also, is the frige working OK? Does the compressor turn on and off normally? I ask because sometimes the compress start device is failing and the refer can warm up quite a bit while the compressor is trying to start up... eventually the compressor will start but by then the ice has melted a little then the compressor runs for a long time to bring the temps down again. Monitoring with a thermometer every hour will show if the temps are lowering in the freezer section too much.
Dec 10, 2006 | Maytag MZD2669KE Side by Side Refrigerator
Maytag PTB2154G Top Freezer Refrigerator Logo
295 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
