Gateway 500x PC started making noise then stopped . now the only thing on is the power button. no sound from the hard drive and no lights on the CD drive. If it is the hard drive would every thing else stop lighting up
  • 72 Answers
Sounds like the power supply has conked out. new ones are cheap and easy to replace. get one from newegg.com and google "how to replace pc power supply" for precautions.. can shock ya dude
Posted on Dec 04, 2007
My seagate goflex desk 4 tb was running fine but out of sudden inbetween it started making clicking sound n stopped responding Sinse then it makes sounds n not detected in my pc n also in disk management...
Hard drives can click for a couple of reasons, 1. the hard drive is not getting enough power to spin up correctly and 2. the hard drive has crashed totally which in fact can be fairly costly if you need data rescued from it - try another USB cable from the hard drive too as this may help.
Mar 31, 2014 | Computers & Internet
My dell home computer is making a clicking noise and will not start
would help if you can get indicators from the system like the color of the light on its power button and if it is blinking, the system may also have 4 small lights in its front or back panel which will also give indicators of the system. Things you can try to do to start isolating the fault is to remove the power cables and the data cables from all your drivers (hard disk, dvd/cd), and remove and reconnect the front I/O panel where the power button is located, remove and reconnect the power connections to the motherboard, remove and reconnect only a 1 working memory module, then try to turn it on again. Try to determine if any indicators change and try to pinpoint the source of the noise. it is possible that this can be from the hard drive, the power suppy or the fans on the system board. if it is from the fans or the power supply, those are the components to replace. if the noise stopped, try to reconnect the hard drive first and test it, then proceed with the CD/DVD drive. If you've isolated the fault, you can then proceed to get the needed replacement.
Sep 06, 2010 | Computers & Internet
I have a gateway 6010GZ laptop it turns on and the cd drive spinns but thats it
turn on the power , tapping delete to bring up the BIOS
on the
main page look to see if the hard drive is being
detected everything that is in the computer ( main comp-
onents ) can be seen in the BIOS goto the boot tab make
sure the detected HDD is
booting up first not the optical drive , when finished press
F10 hit yes to save and see if the computer will boot up
I have 4 Gateway notebook computer , they are very good notebooks however they are notebooks and notebooks are
prone to needing repair tweaks constantly every once in
awhile the sound just stops working like if you switch from headphones to speakers , all Gateway notebooks come with
a reinstall drivers utility , Goto start/programs/gateway recovery center from that utility you can reinstall drivers programs and
many other default setups . there is only 3 things that can make
a computer not turn on 1. the hard drive 2. the video card 3. the
RAM , in BIOS you will see which one of these components are
not working .
Feb 11, 2010 | Gateway Computers & Internet
My friends computer just stopped working while she was using it. The screen froze and than she shut it down. When she tried to turn it back on all that happened was that the caps lock, the scroll, and the...
There are a number of things that can cause this to happen. Try taking the battery out of the notebook, disconnect the AC adaptor (if in use) press the power button a few times. Re-install the battery, reconnect the AC (if needed), press and hold the power button for about 2 seconds. This is a hard reboot and should correct you issue. When the notebook powers up, make sure you remove any cd's in the cd-rom drive.
Good Luck,
C2Solutions
Jan 05, 2010 | HP Compaq Presario V2000 Notebook
My acer Extensa 4420 not booting up
dell inspiron 6000 pc note book or
acer Extensa 4420 which one ? either or sounds like hard drive is shorting out and you need to change it  lala linda
Dec 23, 2009 | Dell Inspiron 6000 Notebook
When i try to power it up it just makes a clicking sound
Open the side of the case and locate your hard drive. Pull the red-yellow-black power cable from the hard drive and see if you still hear the clicking noise when you start the machine up. If you don't, i believe your hard drive is toasted.
Oct 22, 2009 | Gateway 505GR PC Desktop
Gateway 500x power short
your power supply may be dammged or set to the wrong voltave you can make sure it is the right one on the back of the power supply there should be a switch like button with a number
Oct 05, 2009 | Gateway 500XL PC Desktop
GT5034 has power, blue light on power button, no beep, no boot, sounds like fan running hard. Hard drive light is on for a while and both CD drives green lights flicker. Nothing comes up on the monitor. HD...
powersource is good.motherboard might be the problem.harddrive can be tested by putting it in
another computer and see if it boot up.to test the mother board unhook the cd drives and harddrive.turn
on the computer and see if the gateway logo comes on.if it still does the the samething with everything unhooked
then it might be the bios.you might have to flash the bios and reinstall it.to do this i recommend you take it to a
shop.if the comp runs with everything still unpluged and stops then you know that you have a wrong
setting on the harddrive or cd drive.if you got two of anything make sure that you have a slave or master.if you nned me to
write a guide email me at gamecrazy944@yahoo.com or if you got anymore questions.
Jun 29, 2009 | Gateway GT5034 PC Desktop
Accidentaly pushed the hibernation button on my gateway GT 5408
Hold the power button for 3 seconds until it turns off... hopefully this doesn't mess XP up...
Dec 18, 2008 | Gateway (2900147) PC Desktop
Computers & Internet Logo
292 people viewed this question
Alun Cox
David Payne
David Payne
