Question about Samsung HLP4663W 46" Rear Projection HDTV
Tv won't work
The lights on the front are flashing. Then I pulled the tv out from the wall, cleaned it up (thought that might help). Now the picture comes on for about 2 minutes, then the screen gets all screwy with lots of colors. When I try to turn the set off, it won't. I have to unplug it. Can you help. The set is only about 4 years old.
Jay Walden
jay@pomonafirstbaptist.com
  • jdwpraise Nov 30, 2007
    When I turned the set back on, the picture was fine for about 2 minutes, then it went bad again. Does this sound like the same thing you described above?
    Thanks,
    Jay
    I'm not sure what you mean by broken bits of info??? The set does try to turn on and turns itself off and then on again.
    Jay
  • 143 Answers
Check your lamp it might have gone bad if not then on these sets the color wheel goes bad if you get junk on the screen like broken bits of info and you might get a weird sound like computer noise then it might be your color wheel it is a small round glass wheel i just checked to see if your model is in this list of samsung color wheel and yes it is
Posted on Nov 30, 2007
  • 1 more comment
  • marco amezcua
    marco amezcua Dec 01, 2007
    ok did you clean the filter these sets demand lots of air flow to keep the bulb cool this could be a overheating problem
  • marco amezcua
    marco amezcua Jan 02, 2008
    you have a bad color wheel
  • marco amezcua
    marco amezcua Jan 19, 2008
    this set when it turs off does the lights flash in the front if so wich ones
My panasonic tv wont turn on and led light flashes twice
Our Sony TV sometimes won't come on when the switch on the tv is pressed. Weirdly, if we switch it off at the wall socket, wait a few seconds, then switch it on at the wall socket again, the tv switch then works......
Don't understand why this works, but if it gives you a work-around, it would be a lot cheaper than a TV engineer's visit....
Feb 20, 2012 | Televison & Video
Just bought a MadCatz Dreamcast Light Gun - no matter what I try it won't calibrate, just flashes on the screen when the trigger is pulled. Any thoughts ?
The gun could be broken. However, if you're trying to use it on a flat-screen TV (LCD, Plasma, or Rear-Projection), those TVs are not compatible with light guns. You must use an old-style CRT TV.
Jul 13, 2011 | Mad Catz Video Game Consoles & Games
The red light on the front of the TV blinks all the time. No sound or picture. It is a Sony Model KV-21s65
The TV will cause the STANDBY light to blink or flash when the TV detects an issue.
The number of times the STANDBY light flashes corresponds to a specific issue.
If the TV is plugged into a power strip or a surge protector, please remove it from the power strip or the surge protector and plug it directly into the wall outlet.
If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
Also try connecting the TV to different AC wall outlet and check if that helps.
If the issue persists, the TV needs to be Serviced.
The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired.
Please contact the local Authorized Service Center to get the TV serviced.
Nov 22, 2010 | Sony KV-32S65 32" TV
Mitsubshi tv says airflow is blocked
TAKE THE BACK OF YOUR TV OFF , IT ONLY COMES OFF AT THE BOTTOM , ABOUT 6 SREWS PULL IT OFF , MAKE SURE TV IS UNPLUGED, AFTER BACK IS OFF, YOULL SEE YOURE LIGHT ENGINE RIGHT IN FRONT OF YOU, YOU WILL SEE TO THE RIGHT SIDE A LTLLE PLACE WERE THE LIGHT BULB IS ,IT HAS TWO SREWS LOOSEN THE VERY CARE FULLY PULL IT OUT ,DO NOT TOUCH THE BLUB SET IT DOWN CAREFULLY NOW GET A CAN OF COMPRESSED AIR FROM WALL MART AND A FLASH LIGHT LOOK IN WERE YOU PULL YOUR LIGHT BULB OUT AND IN THE BACK OFF THE LIGHT GEN , YOULL SEE A FAN WHEEL IT GET CLOGGED WITH DUST CLEAN ALL OF THAT AND THE OTHER WHEEL ON THE GEN BLOW THE **** OUT OF IT AND CAREFULLY PUT IT BACK TO GETHER YOU SHOULD BE GOOD
Aug 10, 2010 | Mitsubishi WD57831 Television
Problems with mitsubishi WD 65737 tv is locked. what do we do?
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
Oct 20, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Picture and sound gone
your fuses may have blown off.
open the back panel and check all the fuses. There are a bunch of fuses in there, my tv has 5 altogether.
I hope this is the problem.
Feb 24, 2008 | Televison & Video
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Sony KV-32HX15U Flashing standby light
Hi. Thats a nice tv you have there. If your able to get free estimate from repair shop go for it. It could only be dry joints but it could be loptx & other components which could be pricey.
Sep 23, 2007 | Televison & Video
Sony KDF-E55A20 No picture or sound
The little flashing light down on front of your TV will tell you the problem by the color of the light or the blinking intervals, this is the reason you can not turn it off is telling you something. The manual should have a section dedicated to this part, most likely is the bulb, the bulb is easy to access generally hold by one or tow screws you can pull it out to verify the integrity of the bulb. Then again check the LED light before anything then you go from there.
Aug 28, 2007 | Sony KDF-E55A20 55 in. LCD Television
Samsung HLP4663W 46" Rear Projection HDTV Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
