Question about Brother MFC 420CN All-In-One InkJet Printer
Printer trouble I cleaned the print head.  Put the printer back together. Tried to clean the print head. Now I get this error 51 and unable to clean routine maintenance.  What do I do??  HELP! please!
  • 5 more comments
  • ivy12 Dec 10, 2007
    Unable to clean
  • ladybirdrl Jan 14, 2008
    I have replaced the cartridges I keep getting error 51. Where can I take this printer to in the Framingham MA area. contact me at [email protected]
  • Anonymous Mar 23, 2008
    my printer is MFC 5440CN,I have the same problem getting error 41, I called brother and they asked me to take the machine to certified maintenance center to be fixed on my account.
    Now I understand that this problem is well known among every customer, as brother have used the worst type of printing head in their printers.
    if the problem is known to Brother, their moral obligation is to replace the printer or the head at their cost
    it is unfair that customers has to accept brother's liability, sham on you brother you let down your customers
  • bellmarcial Jul 15, 2008
    My black in was out, I put in a new one, and it printed very light, then not at all. I purchased a new ink, installed it, and it has a message "unable to clean review troubleshooting and maintanance in you user guide.
  • Anonymous Jul 30, 2008
    Brother MFC 5440CN : The Magenta ink won't print with the other colors. Cleaning head automaticly does not fix the problem.
  • Anonymous Jan 16, 2009
    unable to clean troubleshooting and routine maintenance chapter in user's guide
  • Anonymous Mar 18, 2014
    display only tells me that routine maintenance is needed. Done that and it still does nothing.
  • 832 Answers
2 Suggested Answers
SOURCE:
Soulvisitor
  • 1113 Answers
SOURCE: brother 420
error 51 = The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses.
Fix is
Switching arm assembly not engaged correctly If the switching arm does not move smoothly, clean it.
Ink cartridge/purge switch harness not connected correctly
Correct the connection.
Purge cam switch broken Replace the purge cam switch.
Gear(s) on the maintenance unit broken Replace the maintenance unit.
Paper feed motor broken Replace the paper feed motor.
Main PCB defective. Replace the main PCB.
Cleaning of these print heads rarely if ever is successfull, they are electronic devices unlike other brands of printers
Posted on Dec 04, 2007
SeeTroubleschooting and Routine Maintenace chapter in user's quite.see clean unable 51 to MFC-230C
Hello and Welcome to FixYa!
"Unable 51" is most likely a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
Your problem will be solved.
For any further help, you can take my valuable,professional help by taking my Service
Thank You for using FixYa
Mar 02, 2012 | Brother MFC-230c Printer
Brother 420
Fix is
Dec 04, 2007 | Brother MFC 420CN All-In-One InkJet...
Error message reads "unable to
It means that the printer is unable to clean the print head number(s) 46. The print head is located under the ink cartridges. Remove the cartridges, and you should see a plastic piece with a hole in it to put your finger under and snap open. This allows you to see the print heads. The print heads look like a sponge type dabber on top of a plastic case. Grab a hold of the print head and pull it out. Look for ink that has spilled behind it or on any of the brass colored computer connections. use warm water and a lint free cloth to scrub it off. Press the print head sponge with your finger and make sure that ink primes and fills the head then put the printer back together and try a test page. If you stll get the error then you need to contact brother for a print head replacement.
Jun 29, 2011 | Brother MFC-465CN InkJet Printer
Canon S900 - No black ink (none!)
Clean the contacts on the back of the print head.
Aug 22, 2009 | Canon S900 InkJet Printer
Unable to clean 51
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Sep 25, 2008 | Brother Multi-Function Center MFC-665CW...
Error message on my mfc 420 mc
this has been written many times here in the forum.
plz search forum "unable to print"
Jun 22, 2008 | Brother MFC 420CN All-In-One InkJet...
Will not print
You have a major error, probally head stuffed error 41, to find out your error press menu starte and up 4 times, this may show error if not then input 82 set, error will display.
Post back if need more info
S.
Jan 14, 2008 | Brother MFC-5440CN All-In-One InkJet...
Error code
and even if you did get rid of error 51 that you have created, you will find that you still cant print in black, original problem is the print head is stuffed probally from dodgy non gen ink running threw it and the fix is to replace head. I don't know who is telling all you brother mfc owners to clean your print head but your paddling up the wrong creek, these heads are electronic deivices that dont take kindly to cleaning, they are not the same as other brands. Re error 51 goto different machine same engine post
http://www.fixya.com/support/t277162-brother_420
Dec 04, 2007 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
486 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
