Question about Motorola Mobility RAZR V3
My phone wont load or went blank
My phone just out of no where went blank with a white screen.I can recieve calls but not answer them and the same thing happens with my text messaging.
    Scholar:
  • 181 Answers
You need to reset the phone or update the software. Either way, back up your data first!
Posted on Dec 06, 2007
SOURCE:
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
Cingular 8125 display problem
you have to open up the phone and try to remove and connect the screen flex cable back to it's original position
Jul 18, 2009 | Cingular Wireless 8125 Smartphone
Sony Ericsson w580i. Dropped it screen blank and calls dont work
I had this same phone and the same thing happened to me. I kept shutting it off and on - also taking the battery in and out. I eventually got the screen to light up but it would only last a few seconds. Sorry to say but you will most likely need a new phone. I had to replace mine.
Jul 15, 2009 | Sony Ericsson w580i Cellular Phone
Sony Ericsson W580i screen went blank
Ok, my phone had the same problem. I took the face plate off and the screen out and there's actually a little connector that connects to a board behind the screen(can come unplugged for replacement). I fiddled around a little with it and it worked fine. about a week or 2 later it happened again. I tried fixing it again and it would just flash white>black>lines>white, repeat. I know my phone's taken a bit of abuse, dropped down a road, soaked in rain, but it always worked after. These phone screens aren't meant to take abuse. Problem; the phone screen died. Solution; get a new screen.
Apr 20, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Home page
I was talking on phone in the car. Made a quick call. Everything work fine. Than the screen went blank white. I can't see the screen of any application. I take the battery out to see if it would reset the phone and turn it back on. It went straight back to the blank white screen. I try another solution. I use my home phone. Call my phone. It signal as it was off mode. Straight to answering machine. Red light flashes....I then, hold #1 to get voicemail. It did work. So my service is good. So my problem is how can I solve the blank screen issue? Has it happen to anyone before. Battery strong and it's not low on battery level. Thanks for any suggestions.
Dec 10, 2008 | Verizon Communications BlackBerry Pearl...
Blank Screen - Sony Ericsson Z525a
Must be bad day for the Z525a. Mine just did the same thing. Apparently is is a bad cable. There is another post within fixya that provides the solution if you are no loner under warranty. Here is the link
http://www.fixya.com/support/t307527-sony_ericson_z525a_blank_screen
Jul 14, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Motorola razr v3 (black) screen has white blank
Well i suggest that you take the case of your phone and have a look at your screen maybe some of the screws have gone missing or the screen has just worn itself out? . Note youll need a t6 or t7 torx screwdriver to do this , hope i helped
Oct 17, 2007 | Motorola Mobility RAZR V3
Screen went blank
have u dropped ur fon? try if you can still recieve a call or a meassage, if so, your flex cable was faulty or cutted. but if you can't make a call if its just white screen your fon program might corrupted and need to be reprogrammed.
Jun 21, 2007 | Sony Ericsson W600i Cellular Phone
Motorola Mobility RAZR V3 Logo
104 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
