Question about Mitsubishi VS-45607 45" Rear Projection Television
Screen removal from vs45va2
How do I remove the cover screen so that I can clean the projectors?
thanks
    Problem Solver:
  • 9 Answers
If you want to clean the projection lenses, you do not want to remove the cover screen to get there. That is the hard way, but you should be an experienced technician to do this correctly. Why do you think that the lenses need to be cleaned? What are you seeing on the screen to make you think that the lens needs cleaning?
Posted on Nov 30, 2007
Hello! I have a DELL 1209S that the picture is wavering. Is it spring?! Some vertical lines almost invisible in the background are also perceived. What can it be?
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Dell 1209S DLP Projector
Red warning light
  • 2
  • 3
  • 4
  • 5
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
Turn off on screen message
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | Dell 4310WX Projector
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
How can I remove the back cover on a SAMSUNG HCR5245W, I need access to clean the mirror and projectors. Already removed all screws. The back cover appears to be made of two parts but I cannot split. From...
Hi my name is Roety,
I can help you with your issue ,
Leave the top rear half bolted on.
Remove the rear edge screws to remove the front half, then remove the front lower section by taking out the few rear screws holding it, then there is another piece just below the screen that pulls off revealing the last few screws holding the top front screen section in the front lower edge.  Take the front off, cleaning the mirror and lens will help, but I'll bet the fluid is dirty inside the blue and green tubes, look into the tubes with the TV on to check.
best of luck
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Oct 19, 2009 | Samsung HC-R5245W 52" HDTV
Toshiba TN50X81 Lens Cleaning
Usally access from rear panel, unplug and only wipe the lens with feather duster. do not mechanically move the projection tubes or you will effect the convergence of the 3 colors
Jun 17, 2009 | Toshiba TN50X81 50" Rear Projection...
My projector nec mt 1075 asks me to clean filter. How do i do it?
All you need to do is use a vacuum hose to vacuum the dust that collects on the filter. The filter cover is on the side of the projector with horizontal slits. You can vacuum through the slits, or remove the cover and carefully vacuum the filter itself. Then go into the menu and reset the filter timer. Find this reset button in the "setup" menu item. Then your clean filter reminder won't show until another 100 hours of usage.
Jun 15, 2009 | NEC MT1075 Multimedia Projector
Sharp XG-P25X - only white screen, no OSD, no response
It sounds like you tripped the tamper switch? Factory or authorized service center and reset via rs232 Sorry.
Apr 02, 2009 | Sharp Conference Series XG-P25X Multimedia...
Hitachi 51F500 Cleaning
the trim on the screen pops off and behind that trim are screws that hold the screen in place...once you remove the screen you can clean the lenses and the mirror and maybe get a cleaner clearer image
Feb 18, 2009 | Hitachi 51F500 51" Rear Projection...
How to take cover off
First, my disclaimer:
I have a much older projector, but the way they are constructed hasn't changed a lot to my knowledge.
An excess of dust can shorten the life of electronics, it's a given. But the majority of these sets are allowed to collect dust for many years of operation before any problem occurs.
I sense that you may instead be asking about cleaning the lenses and mirror. Actually, the mirror, since it faces somewhat at a downward angle in these sets tends to stay clean. the lenses however, face upwards, and do get quite dusty, causing a blurry picture, with ghostly images on the screen at their worst.
To clean the lenses on most RCA sets I've seen, the screen must be removed. Allow the set to cool and voltages to dissipate for 30 minutes before beginning this process. There should be a removable panel beneath the screen, usually retained by screws on the backside at each end. REmoving the panel will expose the screws that keep the screen in place at the bottom. With the screen removed, the lenses (there are three) will be quite obvious. I clean mine with typical glass cleaner and SOFT paper towels. PAY ATTENTION not to allow any liquid to drip into the projector below or you may disable the projector unit possibly causing damage that must be repaired. If you are successful at the lens cleaning you will have restored the picture quality to like new.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Nov 19, 2008 | RCA D52W19 52" Rear Projection Television
Mitsubishi VS-45607 45" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
