Question about RCA MM52110 52" Rear Projection HDTV-Ready Television
RCA MM52110 FUSE REPLACEMENT
My 2001 RCA MM52110 does not power up. It worked in the morning and when we came home in evening it did not. I tried unplugging and replugging 30 minutes later, it did not reste. I am getting no repsonde from unit. I believe it is a fuse or dead power supply. Where is the fuse in the unit , so I may check to see if it is burnt out and also where is the power supply? I can not find any service manuals on it. Any help would be appreciated. I am very mechanically inclined as I do mechanical service work for appliances and spas (not TVs). Please respond. Thank you
  • warren128 Dec 30, 2008
    I have a similar problem. Turned the TV on the other day and after a few minutes the screen went black and it turned itself off. Now when I turn it on, the screen stays blank and in 5-10 seconds it will turn itself off.
Check on the power supply box. Lower LH corner in back where the plug goes in. There is normally a small breaker switch on it.
Posted on Dec 09, 2008
Need help locating the fuse box. tv is not turning on at all.
Posted on Feb 10, 2008
My tv will not stay on
Posted on Dec 24, 2008
I too have an RCA Model MM52110, chassis# MMC102G. I was watching the TV when it went off. Just went black with no prior problems. Hit power and on/off power LED cycles on and off three times and then...
Issue with Heat Sink ,,,, Fan dont work or Hi Voltage Problem
Check The Riding On the Input Output Tranformer Check Regulator Voltage for leakage .... Check Filter Coil, Thermistor and Diode protection On the Hi Voltage Board
Sep 22, 2010 | RCA MM52110 52" Rear Projection HDTV-Ready...
My rca Thompson MM52110 tv picture is too dark even in the light setting mode is there a way I can fix it so I can watch movies and play games in a lighter setting?
Is it a DLP set? Could be the bulb going bad, some times the arc tube in the bulb darkens with age, the arc still fires but less light comes out
Jul 03, 2010 | RCA MM52110 52" Rear Projection HDTV-Ready...
Rca mm52110 color is off, and picture is fuzzy
Ur convergence is dead.Get the convergence kit,use what in that kit.U know how to solder right?Tries this websites.Tv Repair World.com Shopjimmy.com or Ebay.com.
Sep 28, 2009 | RCA MM52110 52" Rear Projection HDTV-Ready...
FL231 Fuse Post
the fl231 problem is unique to the rca itc222 chasis the model mm52100 is not this chasis. wackey? describe the picture. You may have a solder problem or a compnent overheating.
Jan 14, 2009 | RCA MM52110 52" Rear Projection HDTV-Ready...
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
RCA MM52110 tv
I had a repairman out to look at mine today. He said it was the high voltage protecter kicking off the TV as soon as you turned it on. $400 to $600. to repair.
I love this TV but guess I'll go shopping for another plasma. I have one Plasma TV in the bedroom 50" Samsung (top of the line) it doesn't have as good of a picture as my old RCA.
Jan 31, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
RCA MM52110 FUSE keeps blowing
should be covered under your insurance might give them a call.
other wise i would check the bridge rectifier,
Dec 05, 2007 | Televison & Video
RCA Projection TV MM52110 Won't Power Up
Being able to read a schematic and understanding how a TV works are two different things. These chassis that RCA used in these sets can be somewhat complex to troubleshoot. I would geuess that unless the power light comes on at all then you have a dead power supply in the TV.
Apr 14, 2007 | RCA MM52110 52" Rear Projection HDTV-Ready...
Internal Cleaning Of MM52110
Really it all depends on how handy you are. Yes thes sets do have three lenses and a couple of mirrors that should be cleaned every year or two, and a few tweeks on the screens and focus controls. In my opinion, this should be done by someone who knows what they are doing. A TV set is not a place to be experimenting around inside of.
Sep 20, 2006 | RCA MM52110 52" Rear Projection HDTV-Ready...
RCA MM52110 52" Rear Projection HDTV-Ready Television Logo
660 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
