Question about Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Some channels do not have sound.
I use Comcast cable. A few channels do not have sound. But if I take the signal through the DVD player, I get sound. The unit is 2 years old. Thoughts? thanks
  • Anonymous Oct 10, 2008
    I AM HAVING THE SAME PROBLEM EXCEPT NO SOUND ON EVERY CHANNEL. DVD PLAYER HAS SOUND. I ALSO HAVE COMCAST. DID YOU EVER SOLVE THE PROBLEM? PLEASE POST THE SOLUTION IF YOU DID. THANK YOU
I had the same problem on a new LCD TV, with 2 channels not having sound, the rest were fine. I ran a channel scan to have it detect the local channels, and it solved the problem.
Posted on Nov 29, 2008
    Problem Solver:
  • 17 Answers
Try the MTS button or audio button and make sure that it is set to either mono or stereo and NOT SAP.
Posted on Dec 31, 2007
SOURCE:
Tv picture changes and recording is unwatchable when trying to rec one of 4 local channels
It is the signal from the 4 local stations that is the problem, because you can record all others ok. Borrow another VCR and try to record them, if its the same tell the people who run the local channels that they are losing viewing figures, because their channels cannot be recorded.
Dec 27, 2013 | Computers & Internet
Do I need to throw out my GoVideo because it is not digital. Comcast recently went all digital and I cannot get any response on my VCR. Channel 3's view stays consistance from the TV Channel and doesn't...
Not if the unit itself still works; that is, it still plays videotapes and DVDs (with picture and sound).
Check your TV, you may have the wrong input selected for your unit (and/or other connected devices), or the TV is on the wrong channel; hence why you can't see anything from the VCR.
As for the ComCast box, give them a call and ask about it - quote the box number, and ask if it is digital or analogue - if it is the latter, they should replace the box free of charge as part of your cable subscription.
You do not need a new combo unit, unless you want one later which has a digital tuner. All it means is that you have no analogue TV channels in your combo unit.
Apr 04, 2011 | GoVideo DVR4200 DVD Player/VCR
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Unable to receive signal through my Comcast box, but signal is fine from the cable???
It turns out that the DVR has to be on channel 3, and the channels are controlled by the cable box! I somehow had missed that part. With the DVR on channel 3 and the channel being changed through the cable box it is very awkward to try and do any recording unless it happens to be what you are watching, so I have basically given up the whole idea and am planning to return my cable box an go back to basic.
Oct 06, 2009 | Panasonic DMR-EH50 DVD Recorder
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
Comcast Digital Conversion box (cable TV)
You will have to split the signal before it goes into the digital box. The digital box is not allowing the analog signal to go to your vcr so you will only be able to record what you are watching on the cable box (on channel 4). If you split it, you will get all your analog channels back on your VCR (the way it was before the box was added).
Jun 29, 2009 | Allegro DVD/VCR ABV511
How do you hook up to the comcast digital unit to
tune your tv to channel 3 if you're coax cable, if you're using rca or component cable then tune your tv to the proper input on your tv.
Jun 26, 2009 | Apex Digital AD-1500 DVD Player
Will not record digital channels
first make sure the cable is running through you vcr then make sure you vcr is set to either channel 3 or one of the inputs
May 06, 2009 | Philips MWD2206 DVD Player/VCR
Sharp Aquos LC-30HV4U 30 in. LCD HDTV Logo
311 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
