Question about Sony VAIO FRV25 Notebook
Sony vaio my laptop can only power up for 10 minutes. Is this the battery issue?
    Sergeant:
  • 324 Answers
If you are talking about the battery only lasting 10 minutes when the pc is not attached to the A/C adapter, then the answer is most probably yes. It's time to get a new battery.
If you are talking about this happening when the A/C adapter is attached, then maybe not.
Let me know which situation you are experiencing and we can go from there.
Ron-
Posted on Nov 30, 2007
SOURCE:
Sony vaio won't charge new battery
i believe it is a charger issue not a battery issue replace your charger
Apr 08, 2010 | Sony VAIO VGN-CR410E/W Laptop
Turning off
Perform power drain ( remove all accesories including the battery and the power adapter) press the power button for 1 minute.
Connect the power adapter only then turn on the computer - try using for more than 1 hour. If the computer does not shut down then the issue is the battery.
Run anti virus software.
If problem still persist it is a posible hardware issue. If you are still in warranty you can call sony and they can help you fix the issue for free.
Mar 27, 2010 | Sony VAIO Notebook
Need help with a sony vaio vgn-nr220s it was working grate then one morning tried to open it and a black screen with the green light on and hdd ling on for 10 sec. i have tried the 30 sec power button...
Try pulling the battery out leave it unplugged to decharge the board for about an hour. Do not put the battery back in just the power adapter and reboot it. If successful shut down replace the battery plug it in and try replicate the issue. Sometimes they will hold a rogue charge on the board for a few minutes to a few hours.
Dec 29, 2009 | Sony Computers & Internet
Sony Vaio PCG-6h4l laptop turns off for no reason. While using laptop on batteries it works fine and does not power off while using. But while using with electricity the laptop turns off for no reason,...
It could be that the laptop disables it's battery when you connect it with the power supply. When the power supply then fails it won't have enough time to switch back to battery. You'd best first try another power supply, and post back here if that doesn't help.
Jun 07, 2009 | Sony Computers & Internet
Sony vaio pcg-grt170 when I push the power button, the green light and 2 yellow lights blink one time but the computer will not turn on. I tried taking the battery out, checked the power cord.
Perform these steps and the issue will be resolved if the issue is with the Static charges on the Mother board.
I recommend you use Power Drain procedure by following these steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Feb 18, 2009 | Sony VAIO GRT170 Notebook
Problem in hardware in sony vaio VGN-CR220E laptop computer
It should power on when plugged in, even if the battery is pulled out of the laptop.Try holding the power button down for 10 seconds to see if it boots up when its plugged in.
Feb 08, 2009 | Sony VAIO VGN-CR220E/P Notebook
Power on issue
take out the battery of your laptop then put it again, also check whether the cooling fans are working or not, or
you can also check the status of your battery by putting some other working battery
Oct 12, 2008 | Sony VAIO VGN-N250N/B Notebook
Sony VAIO PCG-V505BX Battery life
That is not normal definitely your battery has some problem and needs a replacement because a normal working battery should last for about 2 hours or more..
Hope that helps........
Sep 07, 2008 | Sony VAIO V505BX Notebook
My Sony Vaio Laptop PCG-661R not booting
unplug from power and remove battery and plug back in.
Dec 12, 2007 | Sony VAIO PCG-K25 Notebook
Sony VAIO FRV25 Notebook Logo
64 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
