Question about Hitachi 43FDX01B TV
Hitachi 43FDX10B rear projection tv
When turning my tv off the red power light is staying on but the tv turns off. However youcan still see lights in the back of the tv.
Thank-you
  • Anonymous Feb 11, 2008
    Similar problem. We just went to HD convertor, and found that there is random association with timmyho's problem, however, it also will not turn off at all, or comes on in the middle of the night without anyone around.
Do you have a cable box which turns on and off with the tv? If so is your cable box input on the video 4 mode? If that is the case look under the video menu for advanced selections, you will see a selection for auto/on/off for video 4, select off. Check manul under video and it will explain also.
Posted on Dec 10, 2007
TV will not turn on. Lights Blink and hear noise
Have you replaced the lamp ? Make sure the door cover is closed good because there is a switch that is made when the door cover is put back on. Also you could have a bad ballast board or bad power unit board. Just a thought...... Hope this is helpful.
Oct 18, 2009 | Hitachi 50V715 50" Rear Projection...
Red Power Light Stays on
Hi, you have a leaky diode, it will not hurt your tv it`s just annoying, my Hitachi has done the same thing for a year and I`m just too lazy to change it out, video-tek
Feb 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
My power light stays lit
Good Day, P1Winfrey;;
IT sounds like you need to call a Factory Authorized Service Center for HIT, to come out to your home and give a written estimate B4 repairs begin. Normal cost is about $550.00.
Good Luck, big IRISH. PS too many things on this TV can cause this....sorry.
Sep 01, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Red on/off indicator light never turns off
I had that same problem intermittently for about six months. Now I have no picture, just three small vertical lines in the center of the screen. One red, one green and one blue. Can anyone help? I know its outdated but I'd hate to throw the set in the dumpster if it just needs a little mainentance.
Jul 05, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43FDX10B Power problem
Below is a few possible causes along with verified cures.
Symptom:
Intermittent shut off
Cause: Check auto link and 4 event timer. redress cabling from front control panel away from blue crt-yoke-hv lead
Symptom: NO PIC OR OSD, PWR LITE COMES ON
Cause: CHECK C603 LEAKY
Symptom: shutdown
Cause: T701
Billy
Jan 23, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi rear projection 60" tv, power failure
Yes,it's worth it ! Check for bad C702 capacitor next to HV
transformer covered partially by glue and E994 open pico fuse
in power supply .part # for cap 1-161-754-00 102K / 3KV.......T.
Dec 04, 2007 | Hitachi FDX Series 43FDX10B 43" Rear...
Power light will not shut off.
Sounds like the main relay is stuck, if you know about tvs and what a relay looks like, you can take the back of and tap it with a screwdriver and it will clear up for a while but return, you will need to replac the relay. If not knowledgable call a technician for a repair.
May 29, 2007 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi
if you can hit it and it does something it's telling me you have a loose connection. or cold solder joint.
Apr 28, 2007 | Hitachi FDX Series 43FDX10B 43" Rear...
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43FDX01B TV Logo
98 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
