Question about Siemens Efficient Networks SpeedStream SS1024 Wireless Adapter
Speedstream ss1024 wireless card, cannot connect to internet!! help
I just installed a speedstream ss1024 wireless card into my hp pavillion running windows 98se. I downloaded and installed the driver from driverguide.com. and now the problem, my card will not detect anything unless I change the setting to ad-hoc, then it will detect my router and connect, but.. my p.o.s puter will not connect to the internet. please help, the router is used for other pc's with no problems! thanks
SOURCE:
erbyerb
SOURCE: cant connect my router
what is the source of your connection thru telepon line or a broadband connection or DSL?i need to know this........
Posted on Jul 18, 2007
SOURCE: Siemens SpeedStream 6520 Wireless problems! please help
um not sure, but if you have the disk that came with your router run it and fill in the wireless wizard. Also, on my 6520 the "wireless" led doesnt light up unless i have a device connected that is wireless. Your laptop may be incorrectly setup
Posted on Jul 05, 2008
Yes.Get rid of it.I have a Satellite also and do agree configuration was dodgy at first but the range in Wi-fi was not even 50 ft. as opposed the 100 ft. promised.But finally,after it shorted out my dial tone like most other 6520's I just went back to my trusty speedstream 4100.Good-luck.
Posted on Sep 12, 2008
Eddie333
  • 176 Answers
SOURCE: can't get a wireless router to work with a speedstream 4200
From the telephone outlet the dsl line (telephone line) connects to the dsl jack of the Speedstrem 4200 DSL Modem.
From the modems open port you connect one Cat5 network cable into the port (in back) of the Belkin N Wireless router.
For wireless internet connection to begin you must also do a wireless set-up on the software side of the Belkin router or through their web interface.
Posted on Jan 05, 2009
SOURCE: Can't find the downloadable software any Where
http://members.driverguide.com/driver/detail.php?driverid=1012384&si=ebe61904d7dc8d83c71101a19fa26494
might have to sign up for the free membership, but they do have the driver
Posted on Apr 30, 2009
I need drivers for my speedstream wireless pci adapter model ss1024 802.11b compliant I'm running windows 7 on a 32 bit machine
Hi, if you use this link you can download direct.
Siemens Nixdorf SS1024 Driver Download From.
http://members.driverguide.com/driver/detail.php?driverid=426318
just copy and paste and enjoy life.
Regards Ad
Sep 11, 2011 | Siemens Efficient Networks SpeedStream...
I need the drivers
This site has a driver download for it.
http://www.bioticaindia.com/speedstream-ss1024.html
Jul 07, 2010 | Siemens Efficient Networks SpeedStream...
Everytime i connect to the internet via wireless or ethernet, ny pc freezes. I have uninstalled the drivers and reinstalled them
Update the drivers for wireless card. Just re installation will not work. Also check if you are getting the proper wireless signals.
Sep 09, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
How do i set up wireless internet on my hp pavillion a330n desktop? Do i need a wireless card or is it built in? and where do i put the wireless card if i need one?
Yes you need a wireless adapter.
Solution one : Get PCI wireless adapter which you will insert in an empty PCI slot inside your computer.
Solution 2. Buy a USB wireless adapter, which you plug in a USB port.
However, if my memory serves me right, that particular HP pavillion is 5 or 6 years old, and it does support USB 2.0, just USB 1.1
My advice to you is to buy a USB 2.0 PCI card to be installed in an empty PCI slot )or in the one occupied by the firewire )if not needed). This card will provide 4 or 5 USB 2.0 adapters. Then buy a USB wireless adapter, which you will be able to use with other computers.
Hope It helps.
Rate this solution if it helps you.
Aug 29, 2009 | HP Pavilion a330n (Refurbished)...
My speed stream wireless pci adapter does not work. any time it is enabled it restarts the computer
Hi, you need to follow these steps:
Remove Adapter and Reboot.Download the correct software for your Adapter. For example, there are two versions of the SS1024 driver and they will not work with the wrong adapter.Install the network adapter and reboot.When windows 98se asks you for the location of the driver, browse to the directory in C:\ and select it.From then on, use windows 98se to manage your connection.I hope, it will work for you.
Cheers
John
Ask for any tech Query: +1 (844) 355-5111 (toll-free)
Apr 17, 2017 | Siemens Efficient Networks SpeedStream...
Apr 25, 2009 | Siemens Efficient Networks SpeedStream...
Unable to get on the internet from my wireless connection
If you have a whitelist on your wireless router in your home, make sure that you are allowed on the list. What is happening is that you are correctly connecting to your wireless network, but your router is not allowing you to access the internet. The problem lies in your router, hopefully that should help.
Feb 26, 2009 | HP Pavillion ZV6000 Notebook
How can create a wifi connection with my siemiens speedstream 4100 modem
You need to purchase a wireless router, and install it right after the modem.
Your Direct connect PCs would connect via ethernet cable, and wireless cards - wirelessly.
Jan 09, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Internet connection
HI
Are you connecting using a cable or wireless. Also post the ip address that you are getting. To get ip
start-run-type cmd-in the command window type ipconfig.
also post the firewalls or antivirus programs that you are using.
thank you
rakesh
Jan 07, 2009 | Siemens SpeedStream 2604 Router (obss2604...
New system is seriously messed up
Try the following steps :
Update the WLAN drivers,
Reseat the Wireless Card - Physically remove the card from your system and clean with a dry cloth and then install in the system.
Install the Intel drivers for the Wireless.
Update all the drivers.
Let me know the status.
Good Luck.
Live, Love, Laugh.
Dec 28, 2008 | Laplink Software PCmover for PC
Siemens Efficient Networks SpeedStream SS1024 Wireless Adapter Logo
154 people viewed this question
Top Siemens Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
