Question about Sabrent 1 Bay USB 2.0 External Drive Case
3.5" usb2.o hard drive enclosure
Hello I got a new sabrent usb 2.0 3.5 inch hard drive enclosure. I have my hard drive in it and and connected properly. The power adapter is connected and the cord for the usb port is also connected. When I try to put it on my computer with the usb port the light goes red for a few seconds and then it goes green again. But my computer does not recognize any devices. I am running windows vista on my laptop. However I am having the same problem on my pc which is running windows xp. I have the cd that I can put in, but I am not sure what folder to click on to manualy install the driver. Please help me figure this out.
  • ADIZZ Apr 28, 2008
    I have the same problem, what fixed it?
  • Walt_Barbier Oct 13, 2008
    My Problem is similar. Windows 2000 sees the JMicron Combo device, but it does not even see the hard drive installed in it.
ADIZZ
Changed jumper settings to cs than it worked as advertised
Posted on Apr 29, 2008
  • 36 Answers
You do not need to install a driver for Windows XP and Vista, it is already built in. The CD may however contain optional software for initializing the hard drive the first time, and for making backups later.
Do you know if the hard disk is good? Does it spin up when you turn it on? You can hear and feel it spin up.
If this is not a SATA drive, make sure that the jumper is set correctly. Most enclosures require the drive to be jumpered for Master, sometimes for Single or CS. Check the top of the hard disk for a guide to how to set or remove the jumper.
You might try connecting it to different USB ports, some are faulty.
Posted on Dec 05, 2007
SOURCE:
Iced tea spilled on HP laptop, will not power on, please help?
Salvage the data from the drives and have them copied to your new laptop. At the very least you probably fried your motherboard & damaged your keyboard. To repair them is probably more costly than purchasing a new laptop(voice of experience). The drives may or may not work. Your main concern is the data. You can purchase a hard drive power adapter from ebay to power the removed laptop drive(s) and connect to a new computer via USB port to copy all of your files for about $25 and a little bit of time. Or have a computer shop do it for a fee.
Apr 26, 2015 | HEWLETT-PACKARD Pavilion dv7-4270us...
I have just received the hard drive casings ECS_U35K. I followed instructions. I cannot get Windows 7 to recognize this drive. Any help would be much appreciated.
Sabrent website indicates that this enclosure is compatible with your operating system
http://www.sabrent.com/category/hard-drive-enclosures/ECS-U35K/
this is just an enclosure and you have to put in your hard drive in it.
Supports Standard Desktop 3.5? SATA/SATA II Desktop Hard Drives.
Supports hard drives up to 2TB.
Ultra Light Aluminum Case provides heat dissipation.
On/Off power switch.
LED light indicates Power and Activity status.
Hot-swappable, plug and play, no drivers needed.
Reverse compatible with USB 1.1.
Sep 14, 2011 | Televison & Video
Sabrent didn't come with drivers for windows vista and 7
It states online that it is "Plug-in-Play" and that it doesn't need drivers.
Hope this helps!
Remember to give me 4 Thumbs Up for Helping out the Community :)
~~Dayminner
Jun 03, 2011 | Sabrent EC-7F83 Hard Drive Enclosure - 3.5...
Drive Recognized but not visible on my computer
Right-click My Computer, go to Manage, Disk Management under Storage
Find your drive there and assign a drive letter.
The drive may still need to be formatted.
Sep 01, 2009 | Sabrent EC-UEIS7 USB, eSATA Internal Drive...
I dont understand how to hook up my old hardrive to the sabrent hardrive enclosure
Open the enclosure, plug the IDE cable into the back of the hard drive. Plug the power connector into the back of the hard drive. Mount the hard drive with the included fasteners. Close the enclosure, Plug in the power supply to the wall. Turn on the external drive. Plug in the USB cable to your computer. Browse your files.
Apr 26, 2009 | Computers & Internet
HARD DRIVE ENCLOSURE RECOGNITION BY MY PC PROBLEM
Had the same problem today. I finally noticed that the pin bay on the enclosure was large enough to allow the pins to be offset by one pin set. The open pins were hidden by wires. Once I carefully aligned the pins, everything worked fine.
Robert
Jun 01, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
How to connect a IDE-to-USB cable to a 2.5 inch drive?
1) You will do no harm by reversing the connector, but the PC won't "see" the drive at that point (if your drive has an activity LED it will be permanently ON if the cable is reversed) 2) Most times the USB will have enough power to drive the HD all by itself, but if you are going through a hub that may not be the case. In that situation, plug the device directly into a USB port on the PC.
Apr 22, 2007 | Sabrent (USB-2535) (USB2535) IDE...
Won't function
Firstly it sounds as if the drivers aren't loading properly, right click on your drive (right click my computer> properties> hardware> device manager). Look for your external drive, rightclick and click update driver and force it to look in your cd for driver files. Secondly make sure you are connecting to a USB2 port, as it may not recognise the hardrive.
Oct 25, 2006 | Plumax PM-350U2-PCS V4 Silver Slim USB 2.0...
Sabrent 1 Bay USB 2.0 External Drive Case Logo
877 people viewed this question
Top Sabrent Computers & Internet Experts
WTF Chuck.....
WTF Chuck.....
Colin Stickland
Colin Stickland
Alun Cox
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
