Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Won't recognize my USB
I have a Simpletech USB 2.0 250GB external hard drive. When I plug it in to my pc, it will not recognize it. I have high speed USB ports, but nothing works. I'm using a Dell Dimension 8400. Any idea what I'm doing wrong??
  • Anonymous Dec 31, 2007
    I have a Vista PC, when I hook up the Simpletech 250 G drive, it does not recognize it. I hooked this same drive up to an XP machine and it worked immediately. I assume it is either a Vista problem or my PC
  • charly2 Jan 07, 2008
    I too have a SimpleTech 250GB esternal, the drive does not show up in either desktop, or laptop. the blue light comes on momentarily, but that is about it.
Simpletech USB 2.0 500GB (bought today) took several on/off then it puffed a small (smelly) smoke and fired up. I had rebooted the pc before this happened. I'm not sure if that was part of the problem or if the drive just needed the on/off action to wake it up.
Reading these posts however makes me wonder how long, and if this thing is going to work!
Posted on Dec 22, 2007
    Problem Solver:
  • 13 Answers
I have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Posted on Dec 05, 2007
SOURCE:
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
HP windows 8 does not recognize simpleteck hard drive
I purchased a SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx for my Vista machine and all was well. Then I purchased a Windows 7 machine. It would not recognize the devise. I contacted SimpleTech only to be told my model cannot be used on machines newer that the Vista. Recently I purchased a Windows 8.1, did a little research, plugged the SimpleTech into the 8.1 and reformatted it using the Windows feature. The SimpleTech is alive and well on my 8.1.
Aug 02, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
My windows XP OS won't recognize my SimpleTech SimpleDrive Pininfarina 300GB External USB 2.0 Hard Drive
I found that often, external hard drives just don't have any active partitions and thus don't show up in Windows. Go into the control panel, administrative tools, computer management and then the disk manager and see if it has a partition. If it's just unallocated space, right click and make one.
Jan 16, 2012 | SimpleTech Simpledrive Computers &...
Cannot get computer to recognize my simpletech external hard drive. I have windows 7
A problem I commonly have is if the external drive is plugged in to a non powered usb hub the unit does not have enough power and will not be recognised, ensure it is plugged directly into the pc tower or if you have a laptop try an alternate usb port as some may not be powered.
Mar 07, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Simpletech 160gb
I would guess you are useing USB.
If correct, try a differant USB port.
The USB port you are useing may not be configured for USB2 speeds.
Sep 21, 2009 | SimpleTech SimpleDrive 160 GB External USB...
The computer does not recognize the Simpletech external hard drive. I plugged in a different external hard drive into the same USB port and the computer recognized it right away. What is wrong with the...
not all usb devices work on all machines
You need to find a driver or ask simple tech what the issue is i had the same issue with My WDC drive Western Digital gave me a driver after emailing them
Aug 13, 2009 | SimpleTech 750 GB USB Hard Drive
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
My simpletech signature driver 320 is not recognized by my PC
I had the same type of problem and found when I took the cover off that the harddrive worked loose from the plug. Pushed back into socket and reassembled, works great.
Dec 29, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Computer doesn't recognize the external drive
I asume the connection is via an USB?
Try another usb-port and see if that helps, if not try to connect the disc on another PC (maybe a friends pc) and see is that pc recognize the disc.
Nov 21, 2008 | SimpleTech Signature Mini 250GB External...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
188 people viewed this question
Top SimpleTech Computers & Internet Experts
Ekse
GFXTech
Marvin
Marvin
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
