Question about Samsung PCL5415R TV
Convergence I have a HDTV bigscreen that has bowed convergence. The convergence output I'cs have been replaced but I can't adjust the convergence manually. When I try to use the perfect focus the screen displays NO SENSOR DATA. I was an electronics tech up until 1998 and alot of expierence with projection tv. I don't know alot about automatic convergence. Any help would be appreciated. This is my bigscreen. Thanks.
  • Cris1983 Dec 21, 2007
    Need to know what part is needed so I can look it up and try to find a good repair tech in Tucson Az
    Problem Solver:
  • 3 Answers
Go to this location http://www.eserviceinfo.com search for this file “Samsung PCL541television TV rear projection.pdf “ . Download all 4 files to create schematic diagrams and convergence solution to your problem. You will use the TV's remote to make adjustment to your TV set....
Posted on Apr 02, 2008
    Genius:
  • 1,694 Answers
Corbey1984,
Look for bad pico fuse feeding B+ to convergence amps,two are
hiding under the heatsink amps are on, more fuses in power supply ...............................What part # did you use and what price / mfr. ?.............................T
Cris1983,
please verify your model number on back of your tv..........T.
Posted on Dec 21, 2007
Colors on tv are blurry, almost like when you watch a movie in 3-d, the red and green colors seem to go around the main image
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
The red is curved and dosen't match up
This sounds like you have a problem with convergence - Yhe convergence output IC's would need to be changed - usual repairs cost between $200-$300.
Sep 26, 2009 | Akai PT5598HD 55" Rear Projection...
Blue convergence bows when watching tv, hdtv looks great
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Sep 14, 2009 | RCA HD52W58 52" TV
Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 25, 2009 | Philips 60PP9363 60" Rear Projection...
Toshiba 42H82 Blue raster is bowed to the right in the middle to the rt. The auto convergence give an error.
You have convergence output failure. The output ICs will need to be replaced and possibly a small component like a resistor or two as well. Expect to pay a service company $350-$450 to resolve this.
michtech
Feb 16, 2009 | Toshiba 42H82 42" Rear Projection...
Red Convergence Bowing
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
>>>Solution<<<<
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Jan 02, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
I have a 51 inch phillips seeing almost a 3 d effect
Your convergence chips are toast. You will need to replace them along with the convergence resistors.
Here are some of the common symptoms when your convergence chips fail.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed, wavy, etc but stationary.
Solution:
You can get a convergence kit with photo instructions from www.TvRepairKits.com
Dec 17, 2008 | Philips 51PW9303 51" Rear Projection...
Green is bowing up & down. Phillips 51pw9309/17f
Screen looks 3D
Solution:
Nov 18, 2008 | Philips 51PW9303 51" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
174 people viewed this question
Jerry Greenberg
Jerry Greenberg
