Question about Apple iPod mini 2nd generation MP3 Player
Ipod battery
Ipod says no battery power remaining. please connect ipod to power. I tried connecting it to my computer but nothing happened. Do I need to buy a wall adapter, or is there another solution?
sincerly,
frustrated.
  • OGGDee Jun 27, 2008
    Hi, I have an iPod mini silver second gen. It shows low battery power. I charge with wall adapter and battery shows charged. Then when I go to turn on to use, battery shows no charge. any solutions? Thx D
    Scholar:
  • 96 Answers
Hi all,
Since you guys hav tried many option to charge the ipod... try this out by connecting it ot USB port at the rear of your desktop computer..
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step
also try this out
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Posted on Feb 04, 2009
SOURCE:
Light not working .how to fix
try all this and fix it. God bless you
Hold switch on
Before delving into the guts of your iPod, check to make sure the hold switch isn't activated. If the hold switch is on, the iPod will ignore any input on the click wheel and refuse to do anything. If your iPod's problem isn't so easily solved, read on.
Drained/bad battery
If your iPod won't turn on, especially if it has not been used recently, you may simply have a drained battery. Plug your iPod into your computer or AC adapter and see if anything happens. Ideally your iPod will recognize it has been connected to a power source and charge its battery. If it will no longer charge, the battery must be replaced.
Bad display
It is possible that it appears nothing is happening because the display is bad. If you hold the iPod up to your ear you should be able to hear the hard drive spinning. If the iPod sounds like it is working properly but nothing is visible, it is possible the display is bad and must be replaced
Bad logic board
If your iPod does nothing when plugged into a computer, the problem most likely lies in the logic board.
Bad click wheel connection
If the click wheel is not seated correctly, it is possible that the iPod will not boot. Be sure that the bar on the click wheel is completely flipped down to ensure a positive connection.
Jul 30, 2013 | Audio Players & Recorders
My nano 4 gb ipod does not turn on--turning the switch on and off several times and pressing to turn and nothing happens. I even tried connecting to my computer--and nothing. Can you please help me? thank...
If you ipod will no longer turn on mostly it a battery issue
try this to tell for sure
-connect ipod to computer
- open itunes
- makes sure the hold button at the top is no in the on ( red ) position
- hold the menu and the center button at the same time for 2 minutes
- if the apple logo comes up then it should reboot and go back to the main menu
- if it dose not you need service / repair
Hope this helps
Jun 20, 2010 | Apple iPod nano
My Computer and iTunes does not recognize my iPod
put your ipod in disk mode by following these steps.
press and hold the Menu and Center buttons on the clickwheel. when you see the apple appear, switch your fingers to the center and play/pause buttons.
whena check mark appears plug it into you computer and it should detect and mount.
add music and have fun.
May 24, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
New replacement battery won't charge.
What you can try is to connect it to your Desktop computer USB port at the rear of you computer and charge it for 8 hrs atleast..
then try this step once
and also try this at last
Nov 12, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod 30gb black
Hold down the middle and menu buttons at the same time for about 10 seconds. this will restart the ipod.
hope this helps and good lcuk!
Jaxon
Oct 03, 2008 | Apple iPod MA446LL/A MP3 Player
IPod not charging
your cable might be worn out
Jul 31, 2008 | Apple iPod nano
My Ipod Nano Wont Charge on the wall Charger.
Hello Kawase,
I would suggest you try charging the unit this one time by connecting it to the computer. I suspect that the charger may be defective if plugging the wall charger into the iPod has no effect on the low battery warning. If the iPod is able to be charged from the USB port on your computer that would tend to confirm that the charger is not working. If the iPod does not charge when connected to either the computer or the wall charger then you may very well have a another defective iPod.
Best Regards
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Apple iPod nano 3rd Generation
Ipod 30gb black
hold the menu and center button for 25 seconds.
That will reboot it without damaging your data.
Jun 26, 2008 | Apple iPod MA446LL/A MP3 Player
My ipod doesnt turn on and nothing works... it doesnt charge and when i plugg it to the computer nothing comes up on itunes so i cant even restore it or anything, ive tried everything... please help
hi,
1. Make sure the Hold switch is off
2. Make sure the battery is charged
3. Reset iPod
4. Let iPod's battery drain
5. Update iPod's software
6. Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
7. Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
8. Try connecting iPod to the built-in port of a different computer to see if that works.
IF all the above is checked and if ur ipod still remains same please take it to an apple store and check with them!..thank you!!..
Jun 11, 2008 | Apple iPod nano
Froze/no charge
It has a very low batteyr voltage therefor your computer cant charge it. Buy a wall charger but you may have to put it on disk mode.
Jan 11, 2007 | Apple iPod mini 2nd generation MP3 Player
Apple iPod mini 2nd generation MP3 Player Logo
112 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Parshiv Luthra
Marvin
Marvin
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
