Question about Sony KP-57HW40 57" Rear Projection Television
PIP fuzzes out, then snaps back in
When the tv is in single picture mode it looks fine, but when I switch it to picture in picture, the PIP video feed comes in for about 1 sec, fades to static, then snaps back in, all on a 2 second cycle. This only happens if the PIP is the cable tv mode and only ever appears in the PIP screen.
Help! It's irritating!
PIP fuzzes out....now completely gone...nothing but a black screen with no sound
    Sergeant:
    Champion:
  • 298 Answers
It is definitely a circuit problem tf
it could be the pip board and or
components on or around it.would
require technical knowledge to
repair
Posted on Nov 30, 2007
My Samsung DLP TV's pictures are flickering on the regular screen, but pictures are fine in PIP mode. How do you explain that phenom?
Set uses two tuners, one for regular and one for PIP. If normal with DVD OR SOMETHING INTO REAR INPUTS, MAIN TUNER IS PROBLEM
sd tech
Aug 21, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Mitsubishi TV hand me down
the problem you have is the video goes thru the pip board first and the pip board has a problem this is a known problem. the pip board has some capacitors that leak on the board. the model you mention is CS-27MX1 not XM1 but anyway the back casing was made for several sets of that size. so the pip is the problem and the bulletin is as follows;
1. NO MAIN VIDEO,THERE IS VIDEO IN PIP ON EXT1 AND EXT2:-CHECK FOR 1VPP OF LUMINANCE ON PIN 1 OF IC7000, IF MISSING OR LOW CHECK THE VALUE OF C7001 (4.7UF 35V), LOCATED ON THE PIP-PCB.THIS CAP MAY LEAK ELECTROLYTE ONTO THE BOARD AND OPENED A FEED THROUGH IN THE PATH BETWEEN C7001 POSITIVE LEAD AND THE EMITTER OF Q7003 OR CAUSE INTERMITTENT COLOR. PT#181P504090. 2. NO MAIN OR PIP VIDEO, CHECK CHECK C7014, 47 UFD 35V ON THE PIP PCB. PART # 181P502060 3. CHECK FOR 7.2V DC ON THE BASE OF Q7003,IF LOW OR MISSING.CHECK THE VALUE OF R7002 (150 OHM 1/10W).LOCATED ON THE PIP-PWB. PT#103P401050 you can by pass this by removing the pip board and jumping the VP connector pins 7 to 9 and 5 to 11
Mar 07, 2008 | Televison & Video
60" Mitsubishi Problems
1. NO VIDEO, BUT HAS VIDEO WITH PIP ON. CHECK C763 (1UF 50V) ON THE BASE OF Q715, LOCATED ON THE UCOM-PCB. 2. NO MAIN VIDEO, THERE IS VIDEO IN PIP ON EXT1 AND EXT2:-CHECK FOR 1VPP OF LUMINANCE ON PIN 1 OF IC7000, IF MISSING OR LOW CHECK THE VALUE OF C7001 (4.7UF 35V), LOCATED ON THE PIP-PCB. THIS CAP MAY LEAK ELECTROLYTE ONTO THE BOARD AND OPENED A FEED THROUGH IN THE PATH BETWEEN C7001 POSITIVE LEAD AND THE EMITTER OF Q7003 OR CAUSE INTERMITTENT COLOR. PART # 181P504090. (CHECK ALL 'SMD' ELECTROLYTICS AND TRACES ON PIP) 3. NO MAIN OR PIP VIDEO, CHECK C7014, 47 UFD 16V ON THE PIP PCB. PART # 181P502060 4. CHECK FOR 7.2V DC ON THE BASE OF Q7003, IF LOW OR MISSING. CHECK THE VALUE OF R7002 (150 OHM 1/10W).LOCATED ON THE PIP-PWB. PART # 103P401050 5. SUSPECT R2045/R2048 (6.8 OHM 3W) FOR OPEN/RAISED VALUE. LOCATED ON PCB-SIGNAL AT 5V REGULATOR IC2003 PIN 5.
Dec 04, 2007 | Mitsubishi VS-60611 60" Rear Projection...
Picture in picture
i am not familiar with this model, but on most sets you will have a button on the remote to activate pip, when active you should be able to adjust channels on the small display with the remote and cycle through inputs. depending on the tv you will either have 2 inputs for your cable/sat/tv feed, or will have 1 with a dual tuner.
check the connections in the back for a second cable input, or hook up a dvd/vcr/game console/etc to test the pip.
start dvd or tape playing, press pip button to display the mini-screen, then use the tv/vcr or input button to cycle through the modes and see if one pops up. most tvs that have pip will also have a swap button on the remote, it may be labeled with text, or it may just look like one screen overlaying another, press that one to swap between displays.
hope this helps,
trin
Nov 16, 2007 | Samsung PCJ522R 52" Rear Projection...
I would guess to say the tuner for the pip is bad.
Nov 05, 2007 | Sony KP-57HW40 57" Rear Projection...
My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Oct 15, 2007 | Televison & Video
Zenith TV E44W46LCD Picture Problem
The PIP module is bad or the video processor circuit. Most likely a main board replacement will be neccasary. Good Luck
Mar 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Mitsubishi cs-26ex1
If your set has Picture in Picture, I would say your problem is with the PIP module. if it does not have PIP then the problem is most likly in the video switching or the video processor Printed circuit board. if you know anything about solid stae serviceing, there is a modification I will include here for the PIP as the module is no longer available and has to be jumped out of the curcuit.. Good Luck. Follow the picture and instuctions to the "T" PS please do not forget to rate this thread
Oct 17, 2006 | Mitsubishi CS-27209 27" TV
Sound but no picture in PIP
You mention that the unit is 2 months old. It should be under warranty and should be covered by the store you purchased it from or the manufacturer. If you or any unauthorized person works on it you will void the warranty and besides that's what you paid for when you bought it. Have it looked at by the appropriate warranty person or facility.
Jul 02, 2006 | Toshiba 46HM95 46" HDTV
Sony KP-57HW40 57" Rear Projection Television Logo
64 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
