Question about Microwave Ovens
Microwave Stays On
My microwave stays on after closing the door. The keypad is blank and doesn't work. Is there a way to reset this or is the keypad bad? It is 5 years old.
  • SueBarkis Nov 30, 2007
    Thanks for the quick response! Now I have more information when I talk to a repairman. I may just fix it myself!
    Sue
  • Microwave Ovens Master
  • 9,173 Answers
Sounds like 2 different problems, but it may talke a few posts to narrow it down.
A blank display could mean that you need to set the clock. If you can't, it may be a bad keypad, a problem on the control board, or a bad door switch or door switch mount.
If it stays on after closing the door, it may be a bad door switch or a stuck relay or other problem on the control board.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We also do repairs on the boards for $39.95 nationwide.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 30, 2007
SOURCE:
The door will not stay closed on the microwave and the interior light stays on. Microwave won't work. Any ideas?
One of the latches for the door, that also controls the light, is broken or loose.
Oct 18, 2017 | Microwave Ovens
Panasoni microwave NN-H965WF fan stays on when door closed
Because Panasonic use an inverter system to generate microwave energy the machine has to cool itself down at a steady rate and this is generally the reason the fan stays on when the door is closed,hope this helps
Mar 04, 2015 | Microwave Ovens
Troubleshooting- microwave turntable and fan run constantly when door closed, door switches test good, timer can be set and oven runs otherwise; need amana microwave ACM1580AS wiring diagram
I'd look for a defective relay or shorted triac on the control panel circuit board. Either could cause this problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jan 24, 2015 | Amana Microwave Ovens
Panasonic microwave door is misaligned? does not close without slaming it, then sometimes the light still stays on and msg displays that the door needs to be closed. other times, the light goes out but...
could be a bent or broken pin in the door - its a safty issue since microwaves are harmful when the door are not shut - return the microwave to the store you purchased it from or get a new one
Jan 05, 2014 | Sharp R-1480 Microwave Oven
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
I have a gourmetwave in my rv, sometimes light stays on dim and turntable turns slowly, no lights on front. if i unplug it it resets. any ideas
It is a door switch problem, or the keypad control board, the fact that when you unplug the microwave and it resets indicates a keypad control board issue, and if that is the case the part alone will rival the cost of some microwave ovens.
Apr 17, 2012 | Microwave Ovens
Start button an 1/2 buttons on keypad no work in my GE JVM150H microwave. Interior light also stays on.
The door has latch switches that are part of the protection and operation when door is closed, is the new door identical and switches match up {same number} if everything checks and the door switches are all working, the door needs to be checked for alignment, if it's out a small margin the switches will not operate properly.
Mar 13, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave just won't stop
One of the door switches is defective, sometimes caused by food particals this is a safety issue and should be corrected.
Mar 08, 2012 | GE JE1540 Microwave Oven
Microwave Ovens Logo
435 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
