Question about Gateway 7322GZ Notebook
Removing the Bezel off a gateway 7322gz
Can you help with instructions on how to remove the Bezel off a gateway 7322gz laptop. I need to get it off to get to the motherboard and do a deep cleaning and replace the DC input
  • Hume May 06, 2008
    Hi. I have the same 7322GZ notebook computer which overheats all the time. All i want to do is expose the cpu and heat sink/fan so i can clean them. Can you give me some insight on how to do that?
    I am pretty mechanically inclined but i dont want to break anything as this was not a cheap laptop.
    Thanks!
The hinges on the laptop are covered with plastiic which is part of the part where your gateway logo is.with the laptop closed unclip those 2 parts from around the hinges. then open the laptop flat and pull the pieces from around the hinges. this will start to bring up the part with the logo.that part is clipped in also so use a small flat screwdriver to remove it. once that is off it will expose 3 screws that keep the keyboard in place.remove those screws and slide your keyboard up to release it from the bottom. when that is done you will see a metal plate. remove the screws that hold it down and remove it. your fan and board are then exposed. Good Luck
Posted on Jul 04, 2009
    Problem Solver:
  • 8 Answers
If you havent yet received a response, here it is:
First, turn the notebook over so that the bottom is up. Remove the 2 screws at the back (where all input devices are located) and I think also the one above where it is imprinted "Gateway 7322" (w/input rating and such).
WIth a flat-bladed scre driver (I recommend taping the tip so it doesn't gouge the notebook), insert it just under the Internet/email/zoom button - above & between the Prt Scn and Scroll keys. Gently pry up, and get the bezel to pop up some. DOing the same thing, go between the F1 & F2 keys and gently pry up the bezel there. With the LCD Screen all the way open (and flat), use fingers to gently manouver/pry the bezel off - being VERY CAREFUL you dont yank out the flat, white ribbon cable that makes all the buttons operate, which is attached to the bezel on one end and the motherboard on the other. Using fingers on the brown insertion area, gently move upwards the brown insertion socket to allow the white ribbon cable to come out. Too much force will break the ribbon enclosure, causing you MUCH greif and expense!! Take it from experience...lol
Posted on Dec 14, 2007
How can I disassemble a gateway 7320gz?
go to net search Gateway 7320GZ; 7322GZ; 7325GZ; 7326GZ; 7330GH; 7330G service maintenance manual pdf download and save file open file and follow instructions on diss assembly ,it can take awhile to find the manual though ,that is what i usually do when working on any laptop.
Jul 24, 2014 | Gateway 7320GZ; 7322GZ; 7325GZ; 7326GZ;...
I have the replacement keyboard for the gateway NV54 laptop. I need basic instructions on removing the old keyboard and unstalling the new keyboard. Can anybody help because Gateway can't help so far.
All them are pretty basically the same. Pull out power cord and battery... Remove the bezel piece top of the keyboard "the thing the power button sits in". When you remove it there should be 2 screws very tiny holding the keyboard down remove them. Under the keyboard there will be the power ribbon DO NOT JUST PULL IT OUT!! There will be like a brown/white clip that locks the ribbon to the board. The brown may be black or even blue that is the locking piece. Carefully lift the clip up and gently pull the ribbon out. If its stuck you have not unlocked it. Pull the old keyboard out and repeat the steps backwards.
Sep 23, 2011 | Gateway NV5468u Notebook
I have a 7322gz gateway laptop.back lts work but nothing displaye
On most notebooks, switching between the internal display and the external display is done by pressing Fn+F4.
Aug 02, 2009 | Gateway 7322GZ Notebook
Replacing Power Button Circuit Card on Gateway W730 K8X Laptop
The instructions for replacing the keyboard include the cover you have to remove to replace the power button pcb. The power button pcb is attached to the bottom of the bezel that covers the hinges/button array. In a nutshell you just remove the 2 screws indicated in the instructions, pry the hinge covers up a bit, then gently pry the bezel up from the bottom. remove the ribbon cable, pull back the small piece of tape, remove the three small screws holding the pcb on, and remove it from the spring clips.
Apr 11, 2009 | Gateway Computers & Internet
The lcd screen won't turn on
Its possible that your RAM has malfunctioned. I had this problem with a friends laptop, and you can try switching the RAM chips, or buying new ones
Mar 13, 2009 | Gateway 7322GZ Notebook
How can i open up my Gateway 7322GZ to replace DC power jack?
Here is the direct link for downloading the manual that will walk you through the procedure you wanna pursue.. It's gateway's original manual n hope you get some idea about how to open up ur laptop
http://www.adrive.com/home/downloadfile/136709577
Feb 13, 2009 | Gateway 7322GZ Notebook
Removing the DC input from a Gateway 7322gz notebook
I tried looking up a manual on how to remove the motherboard on Gateway's support site but they do not provide one. They may have one available that is not published on the site. I would first contact their tech support via Chat and ask if they have one available for download. This would give you specific instructions on how to open the laptop and remove the motherboard so you can replace the DC jack. You will need the serial number from the laptop to open a chat session.
If they do not have one you can try it yourself. I did this myself with my HP laptop and after many tedious hours of work I was able to remove the motherboard, remove the dc jack, and resauder a new one on the board and it worked out perfectly.
If you feel comfortable doing the work yourself first start off by removing the screws on the bottom. You then should be able to remove the keyboard, look for a cable that connects it to the board. Now you should be able to remove the pieces of the case around the keyboard, look for the cable connecting the touchpad to the motherboard. After that you should be able to remove the LCD screen, look for the cable connecting it to the motherboard. Now remove the screws holding the motherboard in and remove the tiny bolts around the external monitor connector and the printer connector if you have one. Now you should have access to the DC jack. You will need to sauder the current one off the board and resauder a new one on. Keep track of the many many screws and try placing the components in the order they came out so will know which ones need to go back in in the proper order.
This is VERY tedious if you are not familiar with working on laptop hardware. You maybe able to find a local shop willing to do this or you can look online for a place that replaces DC jacks on motherboards.
Hope this helps!
Nov 29, 2007 | Gateway 7322GZ Notebook
Gateway 7322GZ Notebook Logo
2,664 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
