Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. Washer
Close the Lid problem on GE Profile Harmony
When I start a cycle to wash, I get a popup window that says I need to close the lid. The cycle won't start.
If I bang on the lid hard enough, sometimes it starts.
Where is the switch located on this model so that I can inspect it and see if it needs replacing?
Thanks,
Kevin
    President:
  • 878 Answers
Kevin, the switch is magnetic operation. You will have to remove the top to get at it. Do this by removing the back panel. Inside the panel on the left side will be 4 harnesses. Disconnect them. Remove the pressure switch hose from the tub. Remove the ground wire. In back on each side of the top panel there will be 2 phillip screws, remove them. Now lift the top from behind and slide foward. The whole top comes off. The lid switch will be on the underside just in front of the dispensor. You can test the sensor by using a magnet. Just open the lid and place a magnet just in front of the dispensor on the left side. The washer should work with the lid up. Catriver
Posted on Nov 30, 2007
Where is the lid switch located on my GE Harmony washer?
It is usually within the lock mechanism, try putting a small bar or something That look like the bar of door latch thru female mechanism, It should start when activated ( stop It when it´s filling up before There is enough water, you should not get swamp... )
Feb 03, 2015 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Why wont my philco washing machine drain or spin
Many washing machines won't spin or drain if the lid isn't closed. It could be that the switch detecting the lid close position isn't working or the tang that presses the switch isn't depressing the switch enough. Check to see if the lid is closing all the way, if so, then locate lid close switch and pressing on the switch with a Q-tip. If other functions stop when the lid is opened and work when the lid is closed then you have another problem. The problem could be in the wash cycle switch, try spin and rinse all the different settings.
Nov 21, 2011 | Washing Machines
Screen says to close lid but it is closed
There is a problem either with the lid lock or the lid locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 30, 2011 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
How do i remove the lid on a ge profile harmony washer?
Use a putty knife to remove the front panel first/
The putty knife will insert between thr top of the lid and the front panel about 2 inches in from each side.
The panel will pull forward then up to remove it.
Then remove the screws holding the lid down.
You may have to open the control console to remove the lid.
Apr 03, 2011 | GE Profile WPRE6100G Top Load Washer
Spin cycle is not working on my GE profile washing machine
lift the lid unplug the unti for 60 seconds plug in close the lid 5 time in 10 seconds
Apr 20, 2010 | Washing Machines
How do you remove the washer door
Thanks very much, but my husband found a way to remove the lid on the washing machine. There are 3 screws on each side of the lid that have to be unscrewed in order to remove the lid.
Jan 13, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
WON'T SPIN AFTER WASH CYCLE
Check belt. If belt is ok then unplug for 2 minutes. Plug back in and open and close lid 7 times slowly. This will reset electronic motor.
Jun 10, 2009 | GE Profile 3.5 Cu. Ft. 18-Cycle King-Size...
GE Profile washer will not spin
theres a SAFETY SWITCH underneath where the TOP LID closes , when lid is close it will activate the SPIN CYCLE , check SWITCH with a multimeter for continuity , hope this solves your problem , thanks AJ
May 20, 2009 | GE Washing Machines
GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Jan 29, 2008 | GE Profile Prodigy WPSE4200A
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. Washer Logo
599 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
