I can print and copy, the scanner functions but the documents go to never land. How do I get the docs to my desktop, a file, email, etc.? The scanner does not seem to know its' address or the addresses of the pc's on the network.
Yes, the Sharp AR-BC260 scanner/printer/copier is on a small network with two PC's.Yes, the Sharp AR-BC260 scanner/printer/copier is on a small network with two PC's.
Hi I dont work on Sharp machines but this may help
If a PC or network is running DHCP it means the IP addresses are on a short lease and are called Dynamic IP addresses. If DHCP is turned off then your PC's are running Static IP addresses which means that they will not change. Ok...if you are running dynamic IP addresses your scan to PC destination will have to be the host name of your PC and not an IP address eg james. to find out, do the following start,contol panel,system,computer name.
Connect the scanner to the PC install the scanner software, place the Document on to the scanner and close then on your PC desktop or open My Computer right click on the scanner icon and select scan picture. Save the picture or the document, open your e-mail after typing or just how you usually send e-mail, 0n the send option bar/tap select add attachment wait to open then locate the scan doc by browsing the pop-up menu select your scan doc and click OK/ADD the doc will be added to your e-mail message now you can send it.
Here are a few things you can do with a scanner. Copying Documents - You can turn a good flatbed scanner into a copying machine by scanning in those receipts and other important documents and then use your printer to have a copy or just keep a digital copy. The best thing about this is that you could use software to improve the documents, if you need to take out a grease smudge.
Other things a scanner can do is copy a quick recipe out of Grandmas old recipe book, or a page from a magazine that shows the instructions for a new at-home project you have been wanting to do. Maybe there are some old documents in the family that you would like to have a copy of for yourself, those can be added to the computer files just as any other document. Scanning Photos For Printing - Photographs are nice especially if you are a professional photographer, but you could use the photos for websites to display your latest DIY project. The images could be used for desktop wallpaper or sending to friends and family through email. Because they are digitized you can use computer software to edit them, and make interesting images on top of the first.
Here is something else you could do with a scanner and software. Using the edit feature you can enlarge your projects on the computer screen and then print out only that part. This allows you to make a full-sized pattern of anything you wish, turn around and use it to trace the object on plywood. Once you are done, cut out life-sized reindeer, cows, antique cars, you name it. Faxing Documents - You can Fax a document that is already in your computer, but if that document is on a sheet of paper, you have a problem. A scanner can scan it in, then you can send it out by using the fax driver. When you have long distance relatives, and you find something in a magazine that they need to see, put the magazine in the scanner and then from the computer send them the information. OCR - Optical Character Recognition (OCR) software is used to convert images to readable text. Once they are converted you can use a word processor to make the changes that are required. OCR software usually comes with the scanner.
There always seems to be a need to try getting a hard copy of some document or picture into the computer files, and a scanner is the only way to achieve that. Having a good scanner could really improve your home or office by allowing you to copy, organize and save important files and photos on your computer.
Scanners only see millions of dots. Unless it has software to convert a picture into a document, all documents are seen by scanners as pictures made of of millions of dots. Software is available to convert it to a Microsoft Doc format but it is very expensive.
How often do you need to "copy" documents. Do you have a document scanner? Your Epson is a printer. You'll need a scanner to scan a document into your PC then you can print it out on your Epson. If you only need a copy once in a blue moon, and you don't have a scanner, save yourself a few bucks and just go to Kinko's or maybe even your local grocery store or library and run your copies there. They probably cost about 25 cents a page. A new scanner will run you about $100 bucks. If you decide that you need a scanner, you might even want to consider investing in a multi function printer which will scan-print-copy-fax. Hope this helps. If so, please remember to rate my solution. Thanks.
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner.
If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
First, I would install the latest driver for this printer. Before scanning, select 'save as file' option and save the document as a PDF. That should allow anyone with Acrobat Reader to open it. Hope that helps!
is this a network scanner?
